Question about Vacuums
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Posted on Apr 16, 2008
2 Suggested Answers
  • 240 Answers
SOURCE: i have a Hoover v2 steam vac F7430-900 the water
This is most likely due to a problem with the solenoid on the rinse side not opening. The solenoid may require replacement.
Posted on Jan 21, 2011
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover v2 steam vac F7430-900 the water container will not dispense water only soap yes, any idea to fix this problem?
Jan 17, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
When in the wash mode it does nothing, but the rinse works just fine. what do I need to do. I have cleaned this also. Hoover F7220-900 steam vac v2
There are two possible causes:
(1) defective switch in handle (not likely), or
(2) defective electric solution valve in the base of the unit that switches the solution dispense ON and OFF. This requires a major teardown to access, the removal of hood, drive transmission, and the motor cover.
Oct 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet steam clear
Is this a V2? The F5914-900 just has a solution tank. The V2 has a small soap tan attached to he water tank. If you have a V2, the seal or plunger at the bottom may be bad and can be replaced. The reservior asm. that the tank sits on may be bad. You may have a problem with the tank in which case it will have to be replaced.
May 08, 2008 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
402 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
