Question about HP DesignJet 1050c InkJet Printer
Cutter Problem I have a 1055cm plus with multi-roll feeder. The plotter began making what can best be called a rattling noise when cutting yesterday. Since the noise began the cuts have been getting a little ragged. Not necessarily torn but definately not clean either. This morning during a print job the carriage stopped after a cut and the plotter displayed the error "Turn printer off and check print path." When checking the path I discovered a black rubber washer approx 3in in diameter wedged beneath the carriage underneath the black print head. I'm unable to determine where the washer came from, and the cutter continues to rattle. Any advice?
  • HP Expert
  • 141 Answers
The cutter has that bushing attached to act as a tire as it travels across the scan axis, these infrequently wear out and cause the carriage to basically drag the blade behind causing your uneven cut pattern, the cutter must be replaced. If you need direction on how to do so please contact me
Posted on Sep 09, 2008
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
HP DesignJet 110 - will not move cutter after job is printed
for paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
Jun 10, 2008 | HP Designjet 110plus nr InkJet Printer
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
Red light comes on nothing ells
The Designjet 1050C Plus does not need the hard disk drive to boot. When only the red light comes on, the firmware ROM is probably missing. Open the small panel on the back of the plotter to access the memory and ROM slots. If the FW ROM and memory are missing, you will need to buy them to make the plotter boot. They can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Oct 01, 2013 | HP DesignJet 1050c plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
Overlocker not cutting and, rolling fabric and tangling thread. It began when I went over a seam. It began to roll the fabric under rather than cutting. It then stopped and tangled the thread. Tried...
look on yu tube for a video on doing a rolled hem, and you'll see how to move the blades. perhaps you have accidently just moved them and need to engage them properly; good luck
Sep 14, 2010 | Singer Sewing Machines
HP DesignJet 1055cm Plus system error: 04C300 001F0000.
Its either the EIO card, make sure its seated properly, or the hard disk drive has failed in your plotter. Try running the plotter with out the hard disk drive, it is static sensitive, so make sure your grounded before removing it.
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
DesignJet 5500PS InkJet Printer WILL NOT CUT THE
check the media you have selected. if you have the wrong media selected, the cutter will not work.
Nov 03, 2009 | HP DesignJet 500ps InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
DEsignJet 1055CM Plus (Plotter)
It is most likely the network card. Take it out of the plotter(while it is off nad unplugged) and restart it to see if the problem returns
If it does,it is going to be the hard disk..
Dec 10, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
684 people viewed this question
Ben Johnson
