Question about Sony Handycam DCR-HC14E Mini DV Digital Camcorder
LCD The LCD of my DCR-HC17E is not showing the menus when I switch it on. The screen remains dark as if I did not switch it on. However, when I close it, I can still see the images through the viewfinder. could it be that the connecting flexible strip between the LCD and the camcorder is damaged. Is this replaceable or once it is damaged it cannot be changed. Thanks in advance for any assistance you can give me cawcaw
  • Anonymous Dec 24, 2008
    hi, i am mahendran from India and i bought dcr hc17e in germany.I also have the same problem. Any suggestions ? Please ?
I have contacted Sony Netherlands and they told me that with the HC18 there are known problems with the display, due to problems with the CCD chip in the HC 18. Whether these are the same problems like the HC17 and whether the HC17 uses the samechip are not clear to me. Anyway, the HC18 problems will be repaired by Sony for free. So I will try the same with my HC17.
Posted on Jun 17, 2008
I have the same problem. Any help? ;-(
Posted on Jun 01, 2008
Driver for sony camera,model DCR-HC17E
You can download the driver down here in the link below. I ran a test via Avast!, Norton and AVG and the file is safe and working properly.
http://www.nodevice.com/driver/DCR-HC17E/get39684.html
Mar 08, 2011 | Cameras
Sony handicam dcr hc17e can play back previous recordings but wont record says shutter is closed when its not and tells me to reattatch battery when it is attatched
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Oct 25, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony DCR-HC18E, the backlight on the LCD screen will not light up, it does record but you can't see what you are recording and can hardly see the on screen function / menus. Pressing the backlit buttons...
If you close lcd screen in its position, do you see image in eye piece (view finder) ?
If yes, then replace flexible ribbon connecting wire between camera board and lcd board to get picture in lcd screen.
Let me know if you need part number of flexible ribbon wire.
Thanks.
Apr 21, 2010 | Sony DCR-HC18E Mini DV Digital Camcorder
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Dec 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony dcr-hc17E display not working
I have a sony dcr-hc17E camcorder and my display is gone black... All of the funkcions on touch screen work,but there is no pitcure,no video,no nothing...
Nov 25, 2009 | Sony Cameras
I have a Sony DCR-HC17E. Suddenly LCD screen went blank... What can it be?? can isolve the problem without going to sony?
Most likely, you can not, ribbon cable connecting LCD assembly to main board is broken and it comes as hinge assembly. So, you will have to buy at list the part from sony.
Nov 09, 2009 | Sony Video Cameras
Laptop screen very dark very,very,difficult t read.Laptop has t0 be lnked to an ouside monitor
You have lost the lcd backlight, probably the backlight power supply, this is very common. What type of laptop is it?
Jul 16, 2008 | Intel Motherboard
DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Jun 30, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Touch LCD points not opeating properly
How often have I heard the phrase - Read the Manual - however I admit to a slight case of panic as I have an important bit of videoing coming up soon....however as the Manual says... The solution to LCD touch screen hotspots not working is re-calibration.
With the Sony DCR-HC22E (also the HC17E/HC19E and HC 21E still Digital Camera this is achieved by
Eject the Tape
Disconnect any Connecting Cables except AC Adaptor or the Handycam Station
Slide the Power Switch Down to turn on the Play/Edit Lamp WHILE pressing the Disp/Batt Info for about 5 seconds
You should then get a screen with a cross in one corner
(The manual recommends touching this with the corner of a memory stick however I GENTLY touched it with a biro. In my case a further 2 crosses appeared and after touching them the LCD Was Re Calibrated.
I re-started my Camera and all the touch spots ( Fast Forward, Menu etc all worked perfectly) Remember you cannot Re-Calibrate with LCD rotated
May 25, 2008 | Cameras
I found the link to get the drive on the sony website in the United kingdom. http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?l=en&m=DCR-HC17E
Hope this is helpful.
May 10, 2008 | Sony Handycam DCR-PC105 Mini DV Digital...
Sony Handycam DCR-HC14E Mini DV Digital Camcorder Logo
225 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
