Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error Codes F dl and F 11
After reading your posting dated 10/27/07, we followed the steps to reconnect all the wires to the CCU and ran the diagnostic routine. The unit passed, but I still have the same issue. Any other suggestions?
Thanks
  • Hallsvapor Apr 16, 2008
    We are receiving the following errors: F dl after running load for about 3 minutes. I try to cancel it and then start it again. The machine will continually give the F dl error. If we cancel the load and try the drain/spin option it may start or will give a F 11 error.
    Also I know that I the load will probably make it give I hear the locking click when the machine starts. If I hear a weak electronic buzz when it tries to start I know this load is not going to start and I will receive the errors as discussed above.
    Reading someone's problem you had suggested reconnecting all the wires to the CCU and ran the diagnostic routine. We have done this. The
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Reconnect wires to the CCU for what? Did you recently replace the CCU? What same issue are you still having? Please elaborate on what you have done, so I can give the correct advice.
  • 5,911 Answers
Okay...it sounds like you have a bad door latch assembly. It makes contact, washer begins the wash cycle, and then after some vibration becomes unlatched and generates the "Fdl" code or "F11". "Fdl" is a door latch error, "F11" is a serial communications error to the CCU. A door latch problem can generate BOTH codes, because it has a communication link to the CCU. I would recommend replacing the door latch. You can find the part at either repairclinic.com or searspartsdirect.com. Just type in your COMPLETE model number in the Search menu and you will find a listing of all the parts. For instructions on how to replace the door latch, go to my profile and look under "Tips and Tricks". I have a write-up listed there on how to replace a door latch on a front loader. If you cannot find the information you are looking for, or have any further questions, please let me know. I hope this helps you.
Posted on Apr 16, 2008
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
The wash cycle stops before it finishes and reads either f-11 or dl. What can be done?
F11 Error
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check The following things:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F dl Error
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check the following things
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank You
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and DL error on Whirlpool Duet washer. Please help
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite - dl error F11
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
What does the F11 error code mean? And then it says DL.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%&%
Apr 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front load elite
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
Stops mid cycle.. giving me an F11 CODE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%
Dec 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have had F DL code and now F 11 code? I know FDL
"F11" is a Serial Communications error code. This means there is a loss of communications between the Central Control Unit (CCU), Motor Control Unit (MCU), and/or controls. The following link explains:
http://www.fixya.com/support/r3608695-f11_error_code
If you are receiving BOTH error codes, this means the CCU is not communicating properly with the door latch mechanism. This can be an indication of a broken door latch, failed CCU, or interconnecting wiring between the two. The CCU has a small relay on the board that controls the door latch. These boards are not serviceable, and if defective, must be replaced.
I would recommend you try these procedures first:
1. Remove the top panel of the washer by locating and removing the three screws that hold the panel in place in the rear. With the screws removed, the panel will slide back, then lift off.
2. The CCU is located directly behind the wash tub. Trace the wires that lead from the door latch mechanism. In the area where the door latch connector plug is connected to the CCU, tap the CCU with a screwdriver. Sometimes the relay on the board sticks and the latch will not lock.
3. If the door latch still fails to lock, UNPLUG the washer and disconnect the door latch connector plug from the CCU and reseat it. Do that same thing on the door latch. Sometimes the connectors become corroded and reseating them can restore connectivity.
4. If you still have problems perform a continuity check of the wires that lead from the door latch to the CCU.
If the error code(s) still persist, most commonly this is a CCU failure. Since the control board cannot communicate with the door latch, both errors will be generated.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about any of these procedures, or need additional assistance, please post back and let me know. I hope this help you.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 and dL codes
Mar 05, 2009 | Kenmore Elite 45986 Front Load Washer
"F" code then "dl" flashes, won't continue
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
162 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
