Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual and the remote access instructions.
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
SOURCE: I don't know how to delete message on a uniden
While the message is playing, click the top button, the one with the circle with a line thru it. That will delete the playing message. If you wish to delete all messages, click the top button when all messages have played, then click once again when the prompt says "delete all?"
SOURCE: info to change message
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
SOURCE: I have a Uniden DECT 6.0. How do I delete the
This probably applies to your model:-
From the expansion handpiece - while the message is playing - hit the 4 button - or 4:delete button.
From the base unit - while the message is playing - hit "delete".
You can only delete all messages at once from the base unit.
