Question about Frigidaire ATF6000ES Front Load Washer
Why does my machine display test when choosing a cycle?
Whilst choosing a cycle and pressing start the display just reads 'test', we have tried switching off and unplugging and choosing alternative cycles but the same thing happens. Do you have any suggestions please. Nick
  • 868 Answers
Is ther water inside the machine???
Posted on May 21, 2008
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
My Bosch maxx6 takes very long on wash cycle
Possibly heater fault....if you set unit to, for example, a 40 degree wash, the machine will just keep washing unit it reaches selected temp, then drain and do the rinses. If the heater is open circuit then it will wash and wash and wash until the module times out because it is not getting there and continue to rinses, making the programs excessively long. (You may also find, if it has a display that it sit at 0.01 for a long time at the end of the cycle. Not sure of your model as you have not posted it, but if you go through the test below you can test the heater.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 90 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
The tub will fill a little and if the heater is ok, after a few minutes you will hear it 'kettling', the drum does not turn during this test.
If you have a meter that checks amp draw, if the heater is ok it should read around 9 amps.
Hope this helps
Mar 23, 2013 | Bosch Washing Machines
How do I run Test mode for a Bosch SHU5302UC dishwasher? How do I drain and cancel and wash cycle?
Don't hold me to this but I believe to reset during a cycle you press simultaneously the two buttons with a dot under them (2nd in from the left and 2nd in from the right) 0.01 or 0.00 comes on the screen and the pump will run. To run a test cycle turn machine of, press and hold the same two buttons and turn machine on whilst holding them in, the machine code should show in the display (usually a number in it's 20's), release these two button and then immediately press them again, this should initiate the test cycle. The d/w should now run thru a test cycle. If no fault is detected the display will show 0 or 1. If anything else, please repost and I will try to let you know what the fault code represents. test sequence is usually is as follows.
Pump, fill, circulation motor, dispenser (listen for it to open), heat to 65 degrees, regeneration flush, intermittent pump, sensor recalibration (if the d/w has any), alternate fill/pump, pump, finish. Take approx 10-15mins to complete.
Hope this helps, pls feedback or reply if unknown code appears.
Jul 12, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune in spin cycle goes slowly fav6800aww
Hello smithe623
I’m an owner of the machine.
I assume the machine is not displaying and error code to the LED Display?
I would download the Service Manual and go to page 14 and perform the Quick Spin Test in Service Mode.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
The Quick Spin Test will spin the wash basket up thru all RPM ranges starting at 90 RPM .15 =150 RPM, .35 = 350 RPM all the way up to .85 for 850 RPM. Report back on the results of the Quick Spin Test and we will go from there.
You can get out of Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or press the off button on the console.
Take care…..Rich
Nov 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washer doesn't drain and won't spin it has a fault code of lr what's up with it
The problem was with the component that i suspected, the motor control board. I replaced it and everything is operating as designed. Thanks for your feedback and confirmation of my thoughts.
Nov 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LOC message
This sounds like a faulty micro switch on the door catch. Try pressing inwards on the door glass at the catch area whilst you press start and hold it oressed for a few seconds until it either starts or displays the error again, if the error shows it may require a new switch, the switch can be tested by bypassing it and joining the two wires together that plug onto the switch. The switch can be accesses by removing the dor seal from the outer most edge.
Jan 26, 2008 | Washing Machines
Test display
hi there let your machine do the compleat test cycle again then when it gets to the end press and hold the start/cancel button and the on/off button at the same time for at least ten seconds.
hope this is of some help
Dec 14, 2007 | Hotpoint Aquarius WD640 Front Load...
Display lights
make sure there water going to machine, remove fill hose to see check inlet filters.good luck eire
Dec 07, 2007 | Hotpoint Aquarius WD640 Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
