Broken document feed hinges on xerox work center m15
    President:
  • 2,072 Answers
Here is a good link to order those.
Easy replacement.
https://www.partsdrop.com/store/
One thing I would recommend with replacing those is to buy some longer number 8 screws. I normally use 3/4 inch screws when I replace those, It secures them much better.
Posted on Apr 16, 2008
Eror code 005 285
It is a document feeder problem.
A broken plastic sector gear causing the nudger roll not to drop to feed the documents.
Aug 31, 2010 | Xerox WorkCentre Pro 123 Copier
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Line down center
Often this is merely a mark on the scanner glass. When using the automatic document feeder the light/sensor will stay in one spot and motors will feed it. Make sure to clean the glass in this part usually left of the large glass area is a smaller strip see if there is a mark on the glass there.
Jun 11, 2009 | Xerox DocuMate 510 Document Scanner
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox M15 Prints dark only on copies
If your on maintenance tell them you want a replacement. If you have a maintenance agreement you are entitled to an identical replacement. Write a letter, with the serial number, peoblem and tellt them you want to exercise your TSG agreement. Total Satisfaction Agreement.
Not fixing it is rediculas.
Jan 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Mac imac 2008 driver for m15 work center
what OS?
OSX may have a generic driver built in, but earlier OS's don't, for sure
I couldn't find a mac driver anywhere,
sorry
hope this helps
Apr 10, 2008 | Xerox WorkCentre M15 All-In-One Laser...
Scanning tray not working
Check that the hinges that are on the ADF (the bit that you can lift to reveal copy glass) are not broken, the left side hinge breaks, causing the ADF switch (also on left) to not close, causing problems like yours.
Oct 03, 2007 | Brother MFC-8440 All-In-One Laser Printer
Xerox M15
"Heater Error" doesn't just mean the lamp is faulty. It may actually be getting too hot due to a dirty thermistor or thermofuse. Clean those before going any farther.
Apr 14, 2007 | Xerox CopyCentre C118 Copier
jasbo
jasbo
