Question about Kitchen Ranges
My hoover fan oven hfo 415 x has stopped working and appears that no power is going to it. Have checked fuses but no joy. This cooker often cuts out and i thought it was this originally but clock and everything else is not working. Any ideas will be appreciated
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Posted on Jun 08, 2007
IrishDruid
  • 2712 Answers
SOURCE: range control panel
Hello maud2,
Not sure if this will help, but here are the user manuals in pdf format for your cooking range (not sure which version you have):
Classic 110 All Electric Ceramic
Classic 110 Gas
If your clock is totally melted, then as my friends above have suggested, it is best you contact Rangemaster or a competent local serviceman and have them replace the timer panel. This will prove to be in your best interest, after all.
Wishing you all the best and good luck,
IrishDruid
Posted on Apr 20, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
The tall oven has stopped heating up even though the fan and light still work, any idea, are there fuses fitted within the cooker?
Probably the element has failed. If it is a fan oven, the element is around the fan at the back of the oven. You take the covering plate off, and then remove the element usually attached with a couple of screws. Turn power off first!
Check continuity of element with a voltmeter. If it has failed, they are usually available on-line
Apr 09, 2016 | Ovens
What can stop my cooker from working,
There may be a thermostat inside which quit working.
Jun 29, 2015 | Kitchen Ranges
If fan element fails on a Smeg dual fuel cooker will it stop cooker from turning on? The clock works but no other lights. Cooker not set to Auto. Is there a fuse or other power cut off? Checked topThermal...
If there are other touch switches that are not responding, then the fan failure might not be your problem. If might just be the electronic control board itself. Before you speak of 'fan failure' check the board to see it it is responsive.
The clock will always work even with fan failure.
Check all the wires and harnesses to the control board...unplug and replug them back in.
What is a 'fan element?'
Oct 23, 2013 | Smeg Kitchen Ranges
The lights have blown on my Lamona cooker hood, is there a fuse and how do I access it?
So has mine. At a loss as to what to do as fan not working either. Any joy yet???
Feb 22, 2011 | Microwave Ovens
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Light and fan stopped working
Power problem or fuse .....gotta trace wires....maretts gotta be taped....
Oct 27, 2009 | Kitchen Ranges
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Cooker power has gone.
has it come back on? if not it may be a connection going into the back of the cooker or if it has come back on it may be an overheat stat kicking in -check the blower (cooling) fan is ok.
Mar 16, 2008 | Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
