Question about Toshiba Satellite A45-S150 Notebook
Laptop in continuous reboot after windows update
My laptop recently was updated by Windows automatically. I shut down my system and upon starting it back up again, it was in a continuous loop that I can't get it out of. The problem is that it is continuously starting up and once it gets to the Windows screen it pauses for about a minute and then restarts again and again and again. I've tried starting it in safe mode but it doesn't allow me to do that. I've also tried using the last known good configuration and it still does the same thing.
What can I do to fix this?
  • 5 more comments
  • San_1 Apr 16, 2008
    It is the Toshiba Satellite A45-S150.
    There is no option for me to select disable automatic restart on system failure. I am trying to use the safe mode when it reboots and apologizes for Windows not starting successfully. I'll try to see if I can locate my Windows XP CD.(Not sure if one came with this laptop because it was already installed on it when I purchased it.)
    Thx
    Oh, I do have an authenticity code at the bottom of my laptop for Windows. I'll try downloading it first. Do you know a good site to do this?
    It is a Toshiba Satellite A45-S150.
    It is home sp2
    This time when I restarted the laptop to get ready to insert the CD that I created, it started checking the disk for consistency and found the following file record segments unreadable: 123216, 126212, 128392, 128393, 128394, 128395, 128404, 143844, 143845, and 145476. It is now checking the indexes (stage 2 of 3) and is at 59 percent complete. What does this mean?
    Ouch! It may be the hard drive...I've had this laptop for a little over 3 years now. I guess it's wearing down. It's on stage 3 of 3 now, verifying security descriptors. I sure hope this works.
  • Toshiba Master
  • 13,433 Answers
Hey, in the same menu where you select safe mode, select disable automatic restart on system failure, you might start seeing some bluescreens and post what you get from those bluescreens but the quikest fix for this problem is to do a windows xp repair install with the cd. if you have it.
let me know how it goes after disableing automatic restart.
Posted on Apr 16, 2008
  • 15 more comments
  • Ekse Apr 16, 2008
    Possible reasons
    1. Data corruption
    can be fixed with the xp cd useing repair console and command: chkdsk (you might have to force the check if it says disk is clean)
    If that doesnt solve it then theres the repair install
    and finaly a full reinstall of xp.
    if you have a license code in the bottom of the laptop but no xp cd you could download a copy of the cd or borrow from a friend.
    the code in the bottom is what makes your windows genuie and is required for activation
  • Ekse Apr 16, 2008
    but let me know if you get any bluescreens and post the codes.
    thanks.
  • Ekse Apr 16, 2008
    the cds that came with your laptop might have a disk image .. so it restores the laptop into the condition as when you got it from the shop, but if you have a original xp cd we can most likely solve this problem without looseing your personal data files.
  • Ekse Apr 16, 2008
    you need torrent software like utorrent
    http://www.utorrent.com/
    here are some xp cds
    http://www.torrentz.com/search?q=windows...
    NOTE TO SITE MANAGEMENT, I KNOW THESE ARE WAREZ AND ILLEGAL, BUT AS THE USER HAS THE PRODUCT KEY FOR THE PRODUCT THIS THEN IS NOT SOFTWARE PIRACY.
    Thank you for understanding!
  • Ekse Apr 16, 2008
    you will need to burn the disk ones downloaded. with a program like nero.
  • Ekse Apr 16, 2008
    check the bottom of your laptop, is it home or professional?
    download a cd with home or pro preferably with service pack 2.
  • Ekse Apr 16, 2008
    You can also try to order a cd from microsoft but Ive heard that people have had problems with that. well keep me informed.
  • Ekse Apr 16, 2008
  • Ekse Apr 16, 2008
  • Ekse Apr 16, 2008
    Maanita, sorry, he cant use the windows at all. If you would bother to read the problem you would have seen that.
  • Ekse Apr 16, 2008
    Its correcting filesystem errors possibly caused the bad shutdowns etc. the last possibility is that the harddrve is going bad, but thats only if this thing keeps hapening over and over again(example reinstalling windows many times and same problem comes = bad harddrive)
  • Ekse Apr 16, 2008
    after the repair is complete try to start up in normal mode, if its not fixed run the chkdsk again, if it doesnt help. perform a windows repair install.
  • Ekse Apr 16, 2008
    the time here is almost 23 / 11pm so im going to bed, Will return in the morning - 8 hours.
  • Ekse Apr 16, 2008
    I think it will work, I did this exact thing on laptops and desktops when I still worked at a pc repair shop, if it doesnt, you need a new harddrive, and you can replace it yourself, quite easyly.
    well I've posted good instructions for you, follow them, il return.
  • Ekse Apr 16, 2008
  • Ekse Apr 17, 2008
    Let me know if you need more assistance, and remember to rate my solution if your problem is solved.
  • Ekse Apr 17, 2008
    if the harddrive is faulty, you can buy a new or used 2,5" ide or sata harddrive for your laptop from ebay for examble. I beleave your drive is ide since its already 3 years old.
    heres one for examble
    http://cgi.ebay.com/2-5-Samsung-120Gb-HD...
    Its quite big, 120GB and in australia, il look for another
    Heres a cheap 40GB hdd
    http://cgi.ebay.com/Hitachi-DK23EA-40-40...
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha Apr 16, 2008
    Please run a system restore in safe mode to a previous date when the system was working fine and once the system is restored successfully you can run the windows update later follow the link which will help you.
    INSTRUCTIONS Very imp: To run system restore you need to boot the computer to the safe mode as its not running fine in normal mode
    to do so you need to shut the computer down.
    as soon as u turn the system on keep tapping the F8 key for 3to 4 times this will bring a dos black windows select the one which says safe mode using the up & down arrow key once it is hightlighted press enter this will take you to the safe mode.
    Once you are in the windows desktop you will see all four corners say safe mode you need to click on start --> all programs --> accessories --> system tools --> select system restore hit enter you will see two options restore my computer to an earlier time and create a restore point select the first option the you will see a calender select a bold date which will be the previous date from today, double click the date to highlight the box then click next the system will restart automaticall once its restored successfully you will be able to get your windows desktop back, issue will be resolved.
    You can refer this link for help
    http://www.windowsxphome.windowsreinstal...
    Dont forget to rate fixya
  • Maanita Chadha
    Please go though this link and this will resolve the issue 100%
    http://www.microsoft.com/windowsxp/using...
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
Gy laptop keeps failing configure updates every time i turn my laptop on. its really annmoying me as every time i go to shut down, it keeps doing the same "installing 1 of 2 updates"
Hi ahzeal,
One thing you can do that make some changes in automatic updates. Just follow is these steps:- 1.Goto Start---->Run. 2.Type services.msc then hit enter. 3.Find out the Automatic updates or windows updates(in case of Windows Vista or Windows 7). 4.Change it to manual or you can stop that(Depends on your wish).
Oct 04, 2010 | Computers & Internet
My Travelmate Laptop will not power on. During an automatic update the server went down and the system crashed I had to turn it off when I tried to startup the power button comes on but the power light...
boot into Windows' Safe Mode; press F8 before the Windows loading screen appears to get this option.
Once signed in, you'll be prompted to a) continue in Safe Mode, or b) Restore a previous install point.
Choose option b) and then follow the instructions. If the same problem (black screen after Windows has started up) persists once you've rebooted, sign in with Safe Mode again and restore to an earlier install point.
change the Automatic Update to notify before installing.
Aug 13, 2009 | Acer Computers & Internet
When I turn on my laptop it reads configuring updates 3 of 3 and goes to 100% then shuts down and restarts and does the same thing over again
There may be bad sector on your hard disk, n probably that bad sectors holds the vital windows file.. due to this the windows is not able to load.. format the hard disk, and reinstall windows..
Aug 06, 2009 | Compaq Presario Notebook
C drive filled
It might not help but sounds to me like it updated a lot of updates. You might have to let it keep starting and rebooting till it has installed all the updates.How do you know it filled your hard drive?
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M30
You can try to select safe mode and do a system restore (Start-all programs-accessories-system tools-system restore) choosing the date when your laptop was working properly. If you are using Vista, you would see if you had a Windows Update or other such software changes. It is like undoing that but there would be no changes with your personal data. If your laptop works faster after that, please do not have the same software or update again. Hope this helps. Thank you.
Sep 22, 2008 | Toshiba Tecra M1 PC Laptops
Will not start up after system recovery done with disks.
Try uninstalling your sp2 or any updates a restore from an early date before the update
Aug 28, 2008 | Computers & Internet
Help!
You might have connected to interent and your windows updates are automatically downloaded. You need to install those updates. Actually it did not shut but power goes off may be it was on stand by mode. Now shut down (press Alt+F4) your laptop from menu. Choose Install Updates and Shut Down from the drop down list.
Now it will install updates and after completion it will automatically shut down your laptop. Hope it works
Feb 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Toshiba Satellite A45-S150 Notebook Logo
291 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
