Question about Neff B1641 Single circotherm super Electric Oven
Nef u1461 top oven
How do i remove the glass from the top door unit as fat has seaped down the glass i need to get it out to clean.
there are three screws at the base do i undo them and if i do will anything come adrift as the hinge mechanisim is located there it looks like two of the screws are holding them in place.
  • Mary1958 Feb 28, 2009
    I have removed the Neff b1641 oven door to clean, and when I put back in place there seems to be too big a gap between the door and top part of the oven and it feels like heat is escaping. I tried redoing it but it is not getting any better. Any suggestions? Mary D 28/2/09 Melbourne
Hi managed to clean my oven door this week end! yes you undo the two screws nearest the middle - but you will need an alan key to undo the top glass pops off -there is a spring clasp underneath - just ensure that you leave the door flat whilst you taking it apart. hope this helps i now have a nice clean oven door - you will be able to clean all parts once you pop off the glass - hope i was usefull!
Posted on Jun 03, 2008
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
B. With door in broil stop position lift door assembly off hinges.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Dripped inside top of oven door. Need to clean the glass inside door.
you will have to remove door and the inner part of door comes apart... be careful there is more glass inside than you really can tell... lay the unit on a rug or something once you have it removed and disassemble ... fairly easy process. requires just a couple of tools and a little patience.....
Jan 05, 2011 | Ovens
How do i take the door off to clean it
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Feb 06, 2010 | Stoves 720EF Electric Double Oven
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Neff B1641 Single circotherm super Electric Oven Logo
289 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
