Check the spark plug and also the spark plug wire, making sure that it is fully inserted into the spark unit. Also look for loose connectors at the switch area. I have seen all these.
Thanks I have tried that but no luck is it worth changing the spark plug or unit
I would not at this time change spark unit. It costs about 100.00. are you sure that the spark plug wire doesn't have a cut in it to send spark to ground. If you have removed the front unit and just have the fan and rest of tool assembled, you can check the spark. KEEP fingers away from fan. insert good battery and depress the trigger, the fan should come on and run for a short period. Next there is a roller switch towards the top depress that and again the fan should come on and run for a short period. If this happens now depress the roller at the upper switch and hold in and then depress the trigger switch and you should see a spark jumping the gap. I usually try this several times to make a consistent fire is there. If is doesn't listen for or look at plug and wire for arcing causing the gun to misfire. If none of the above happens and you have looked for loose connections and bare wires I would think that the circuit board assembly might be bad, for this I would recommend taking to a shop that services this tool and ask them to try one first. Nothing on this tool for that is cheap. Let me know what you find and I will try and help further and thank you for the rating. I appreciate that.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
-]0]0-
with them.
If
Paslode
heatman101
