Question about Hitachi 43UWX10B 43" Rear Projection Television
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
I have a 50 inch hitachi ultravision projection screen tv model # 50ux53k anyway the picture was jumping at first for awhile and a few months after that started happening i took off the back and found that if i put pressure on the circuit board it would stop jumping.so i wedged a plastic rod to keep the pressure and it worked fine for a few months and then the picture began to squish to the center (top to bottom) so i then took the back off again to find that the plastic rod fell down so i replaced it and it work for a week or so. then the picture went blank no picture or sound and the power button is on. can someone help.
When I power on tv, seems like it is turning on and off continuously. No video, popping noise. Lamps go on and off also. Thanks in advance
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Posted on Apr 19, 2008
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
Posted on May 21, 2008
if the power button is blicking red then most likely ur lamp needs to be replaced. they dont come cheap but its an easy fix ...try ebay for the part ...and make sure u get the correct seze and watt for that specific tv ....on a side note...if u replace the bulb yourself....wear latex gloves and DO NOT touch the bulb. the oils on your skin will magnify the light and can cause that bulb to explode or pop and then u will be right back at squareone
Posted on Sep 20, 2010
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Problems with my 50 inch hitachi ultravision projection screen tv
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
KIT10 $29.50
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 43UWX10B 43" Rear Projection Television Logo
400 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
