Question about Microsoft Office Outlook 2003 for PC
Loading Wireless G Network Adaptor
When loading Wireless G Network Adaptor the Wizard comes up asking for cd disk but when disk is put into ocmputer it won't connect. If I go to my computer and click on dvd, the programme loads but sends error message saying it is incomptbile with windows. It is possible the disc being used which is appropriate for Wireless G Network Adaptor is not the actual one that came with this Wireless G Network Adaptor.
  • Anonymous Mar 21, 2014
    unable to connect to wireless internet. when I put in security I get the message that there is a possible network security key mismatch. I have verified the security code.
    Problem Solver:
  • 5 Answers
Which OS u r using ......if its vista then there might be compatibility issue...vista is facing huge compatibility issues......try wid XP........
Posted on Apr 29, 2008
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
When i run the setup.exe on windows ME it shows a
if you have the cd that came along with the adapter, you can install manually from that....Click advanced options in the found new hardware wizard and click next...click i ll chose the driver to install in the next page and select the hardware type as network adapters...click on have disk and locate the file rt73.inf or rt73.sys in cd...thats it
Mar 29, 2010 | Belkin F5D9050 Wireless G Plus MIMO USB...
Usb adaptor
you might be knowing about it... but check--
Yes you an can but the purpose of the Wireless Usb adapter is to get the wireless connection from the Router to the PC (Computer)
Connect the Wireless USB Adapter to the usb socket of the computer and install the Drivers with the Help of the CD.
Note to get the wireless connection you need the wireless router connect as well in home network
Jan 24, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
CD installation for Belkin 54 wireless G USB
Try removing it in Device manager. Reboot. may load driver. Also right click on it in Device manager, click properties, then update driver.
Nov 03, 2009 | Office Equipment & Supplies
How to install programe paint shop pro 9 after loading disk how do you get into psp9 thanks
When you put the PSP9 CD in the drive, it should automatically come up and ask if you want to install. Try removing the CD and then putting it back in the drive.
If that doesn't work, leave CD in drive and go to Start button, Computer and choose the CD drive. Look for Setup.exe and double-click on it. That should start the installation process.
Sep 05, 2009 | Computers & Internet
Wireless Adaptor Icon can not be found
uninstall the linksys software / driver. reboot, plug-in the adapter, when windows asks for the driver put in the linksys disk and let windows find the driver. (Do not install the linksys Connect software....). This will fix the issue.
Mar 24, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Loading belkin G adaptor
give the default user name and password.
if that does not work please reset the device and use the default user and pass.
thank you
Dec 29, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Setup problem
lost my set up disk so would not connect linksys wireless b 2.4 ghz 802.11b usb network adaptor
need to dwnload disk drive for linksys wireless b 2.4 ghz 802.11b usb network adaptor
Sep 08, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Printer Sharing
on PC.... go to printer settings and set printer sharing to on and give it a name.
in network settings on both machines ensure they both have the same "Workgroup" name
then go into Network neighbourhood and press button for computer in my workgroup. you should find the PC listed there, double click on it and you should then be able to see the printer listed there, right click on printer and select install.. if asked for driver disk use to install drivers..
job done.....just like making a shared folder.
Aug 20, 2008 | Office Equipment & Supplies
Microsoft Office Outlook 2003 for PC Logo
196 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
