Question about Brother MFC-440CN InkJet Printer
Prints blurry Tried the alignmemnt test print a few times to no avail. Any other way to resolve this issue. Thanks in advance!
  • Karnaq Apr 16, 2008
    Thanks a million! i'll do just that.
  • dan9103 Oct 28, 2008
    There are enough service centers for proffessional printers but everyone says it is cheaper to by a new printer.
    Is there no way to clean te print head? My machine is not even two years old.
    Greets Dan
  • 832 Answers
Yes. If you have alignment probs and cant fix it by yourself you have to take the printer to a service dealer. The personell can do some special alignment which cant be done by users (special service software needed).
Posted on Apr 16, 2008
How do I cure blurry printing please?
You don't say what type of printer you have (some have built-in utilities that can guide you to correct things) but generally speaking, if text print is coming out blurry, you may want to look at the following:
1) Check your ink cartridge. Is it dirty? Is it plugged (clogged)? A good cleaning may help by removing your ink cartridge and swabbing the print head nozzle (check your manual for location) with isopropyl alcohol with a cotton Q-tip. Run a test print. Still a problem? You may need to do this about 3 or 4 times before it clears. If your printer head is way down indide the printer, you can get an eye dropper and drop some isopropyl alcohol on it.
2) Check your quality settings. Perhaps someone had changed the settings from "Best Quality," for instance, to "Draft." Make your changes and click Save. Run a test print.
3) Check your paper type. Do you have the right type of paper for your printer? Inkjet printers require inkjet paper, whereas laser printers require laser paper. Mixing the two will produce poor print quality. I am assuming you have normal copy paper in your printer tray, which is fine.
4) Check for printer software updates. Have you tried reinstalling your printer again, especially your printer drivers? If your printer is an older model, perhaps a software update is needed. Go to the manufacturers website and see if there are any new print drivers for your model. Run a test print.
5) Replace your print cartridge. This could simply be an issue of your cartridge being too old, drying up or defective. After installing new cartridge, run a test print.
Hope this helps!
Pen
Aug 14, 2014 | Epson CX9300F/CX9400Fax/DX9400F
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
I am having an issue with the printing all copies are coming out off centered and blurry....? how can I fix it? thanks
It sounds like an alignment issue of some kind.
Use the instructions here to print a test page, then set the alignment, then print again. Also check to see what your print quality settings are. If that has no effect, try another paper.
There are other print quality tips available here, and your home support page is here .
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | Brother MultiFunction Center MFC-440CN...
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
HP 6310 AIO Won't Print HTML Documents
Thought that I'd report that I fixed my printer. I named my printer wrong btw. It is an hp deskjet F340 All in One.
  • Go to the Tools and select Internet Options. Then go to the Programs tab. Select Set Programs then Set Defaults and then Set Program Associations. Select Internet Explorer.
  • Go to the Tools and select Internet Options. Then go to the Advanced tab. Select Restore Advanced Settings. Restart Internet Explorer and try to print again.
It did not work when I removed the windows updates. I also tried this online help and it did not work. HP suggested that I install Firefox. I did not like this option so I'm glad my fix worked for me.
Mar 30, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP PSC 1402 won't print!
my system ever thing is ok,but once i put paper displaying a out of paper,how 2 resolve this problem
Jan 07, 2009 | HP PSC 1401 All-In-One Printer
Unclear Printing
Your print head is most probably blocked.
First try and run the cleaning program a few more times, it make penetrate deep enough to get through.
If that doesn't work you can either replace the print head or try and clean it.
To clean it you could soak it in a mixture of window cleaner and water (filtered best), but don't let the electronics get wet by this and try to avoid wetting the rubber seals where the ink tanks go get wet by this too, it should only soak the very bottom part of the head.
Let it dry off and wipe any residue with a soft cloth especially on the bottom where the print heads actually are. You may need to soak it a few times to get all the gunk out.
Sep 17, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Brother MFC-440CN InkJet Printer Logo
204 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
