I have a PVX 20 preamp by gemini. the volume knob doesnt seem yo do anything. what is it suppose to gain?
Hi there - did you ever solve the problem? I have one of these and it only seems to have a gain of about 5. As long as you're taking your output from 'Pre Out' 1 or 2, the volume control should adjust from no output to max.
Posted on Jan 29, 2010
My recieve on cb radio doesnt work
Are you sure this is the problem.Some people just don't take the time to read the manual that came with the radio.Looking at the radio did you notice if came on or not,turn the volume knob till you here a click and it should come on.Do you hear a loud hissing noise,if not there is a knob that says squelch on it ,turn it all the way to the left. There may also be another knob that says RF GAIN,turn it all the way to the right. Do you hear anything now?Try hooking up your antenna!!!
Jun 11, 2014 | Radio Communications
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
I have very low volume when plugged into any input and is full of static no matter the gain/drive setting, Is the whole preamp bad or do i just to replace the tube in it, it is supposedly brand new, i have...
if there is static then there is probably a problem with the knobs or (pots) you can try to replace the tube but i doubt that will help. Id say return it if possible if not, then if its new you should be able to get it fixed under warranty. if you need further assistance then please let me know.
Sep 18, 2010 | PreSonus TubePre Amplifier
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Gain on one channel stuck at max
Hi there
Check for a dry solder joint on one end of the vol control(earthy end). This will be causing your problem. The pot itself may actually be faulty to. You can always get stuff like that, just got to identify it. Check soldering to the pot first.
best regards
Graeme
Mar 24, 2008 | Audio Players & Recorders
Turntable problem
You will need a phono preamp. Ipods, radios and cd players all give out a LINE level signal..which means you can plug headphones or speakers, adjust volume and be set. A turntable needs a phono preamp. Usually a dj mixer or stereo receiver with a phono input is all that is needed. A simple phono pre amp is like $20 from radio shack.
keep me posted.
Oct 25, 2007 | Gemini XL-500 Turntable
Channel 1 static and lack of performance
The potentiometer (volume control) is probably dirty. Open the amp and find the "pot" connected to that volume control. You should be able to see small opennings where you can spray electrical contact cleaner inside. Give the knob a few turns and try it out. If it gets better but not perfect, repeat. If several attempts don't eleminate the problem, the pot will most likely need to be replaced. Contact cleaner can be found at any electrical supply store such as Radio Shack. Be sure to use one that says no or zero residue. I use a product called Electrosolve.
Sep 03, 2007 | Crown CE1000 2-Channel Amplifier
128 people viewed this question
 Grubhead
Grubhead
