Question about Acer AL1916W 19" LCD Monitor
Acer Monior 19 in. turns on it comes up with a very good picture then in a few mintues shuts off.
  • 180 Answers
Power board is having problem.
Posted on Apr 19, 2008
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
what kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
Feb 15, 2014 | KDS Computers & Internet
GREETING HAPPY HOLIDAYS T.V, COMES ON THEN FEW SECONDS CUT OFF. PICTURE SHOW WHEN COMES ON & SPEAK. WHEN CUT OFF BLACK SCREEN & NO SPEAKING. WHAT'S THE PROBLEM JUST HAPPEN TODAY. TRULY
This is a power supply regulator problem. As soon as one of the resistors gets a full load, it trips the fault circuitry, shutting down the screen and preventing the screen from destroying itself.
It's either that, or there is a fuse that is almost burnt out, so that, when cold the contacts touch and it turns on, but as soon as it warms up, it turns off.
Dec 15, 2010 | Proview PS 909 (White) 19 in.CRT...
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
Acer monitor al1917w-a problems
I assume that you already try this monior with other PC and still get the same problem. You may have to open it up and inspect the inside, look for bad components such as capacitors in the power supply, the problem can also be inthe backlight inverter circuits also. See example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Acer AL1917W LCD Monitor
Acer monitor will not work, not light no
The capacitors are good, no bulging top/seal? Pictures? see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Pictures will help a lot.
Mar 19, 2010 | Acer AL1914 19" LCD Monitor
Acer al1916 lcd flat panel display turns on but no picture.
yeah, it's fixed, answer already posted, just typing this to stop the site from notifying me...
Dec 15, 2009 | Acer AL1916B 19" LCD Monitor
Monitor not powering up. Theft deterrent?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 18, 2009 | Gateway HD1900 19" Monitor
Monitor problem
It is the problem of command section.Check menu button for shorting.if it is ok then check command ic or component related ith it.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Aug 20, 2007 | Acer AC713 17" CRT Monitor
Acer AL1916W 19" LCD Monitor Logo
61 people viewed this question
Brian Sullivan
Brian Sullivan
