Question about Kenmore 47783 Electric Single Oven
Trouble Shooting The other day, a small, plastic cutting board fell off of a shelf and landed on the top of my range. It blew a breaker for the oven. But, once we flipped the breaker back on, everything seemed to work EXCEPT for my front left burner (one of the large ones). I have no idea why it's not working....please help! :-)
  • 979 Answers
I hope by now it is working. You have probably knocked a wire off or actually have broken the burner itself. Can you check it for continuity.It may not appear to be broken but the coil on the inside may be depending on how hard the board hit the element.
Posted on Jan 29, 2009
I get a start? when pressing start and oven wont come on my whirlpool electric oven
Terrence, Could be defective oven element, control board, etc. have a good tech. diagnose and estimate repair. Check the attached links trouble shooting,instruction and guides for electric oven, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool Oven Won Turn on
Troubleshooting Guide for Whirlpool Electric Range
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jul 29, 2016 | Whirlpool Ovens
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Fues blows when small oven turned on
Yes you have a bad connection or when moving the oven it has scrapped a wire bare or you have to small of breaker to run that amount of amps. How many amps does the oven draw? and what is the breaker it connected to rated? Thanks and hope this helps.
Sep 03, 2012 | AEG U3100-4 Electric Double Oven
How do i reset the oven after a power failure?
If your oven won't heat at all, the most likely problem is a blown fuse or a burnt out element. Assuming you're not attempting to repair an antique, your oven will have a clock. If it has also stopped working, it's safe to assume the oven is not getting electricity. Check your circuit breaker box and reset the breaker if necessary and see if this fixes the problem. If not, cut power to the oven at the breaker box before going any further. Note that your oven runs on 220 volts. There should be a double switch on the circuit breaker board controlling power to it. If not, there will be two single switches that need to be tripped to cut power to the oven.
Even if you didn't find a blown circuit breaker, the problem could still be a blown fuse. Some older ovens have their own set of fuses located under the range top, in the back of the oven space, or behind the oven. Inspect the fuses and replace any that have blown with one of the same amperage. Your oven might also have a circuit breaker with a reset button on the control console or on top of the oven that needs to be reset.
If you are still confounded, pull the oven away from the wall. If it is a range/oven combo, make sure it is plugged securely into the wall. If it is a stand-alone oven, inspect the wiring in the junction box to make sure everything is tightly connected and the wiring doesn't show any signs of damage.
Apr 07, 2010 | Neff B1421 Electric Single Oven
I turned on my oven on my Frigidaire Range and heard a popping sound. This blew the breaker. I turned the breaker back on and the stove top works but the oven, broiler and bake do not work at all. The...
To be certain the elements are o/k you need to test them with a meter. I suspect one of them has failed.
You normally cannot always tell if they are o/k simply by looking at them.
Hope this helps.
Jan 11, 2010 | Frigidaire FEB27S5A Electric Single Oven
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Range is not working
i know it sounds obvious but have you checked you oven fuse or circuit breaker - ie in your fuse box?
Apr 17, 2007 | Whirlpool RBD245PD Electric Double Oven
Kenmore 47783 Electric Single Oven Logo
46 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
