Question about Stanton STR8-60 Turntable
No power cable
Hi there, bought a stanton str8-60 deck off ebay but it came with no power lead. Is there a set polarisation on the power input or is it variable?? Can i use a standard 2 pin shaver lead for the power input?
    Novelist:
  • 155 Answers
There is no polarisation on the input lead - It won't hurt the deck if you get it reversed. If you have a shaver lead that fits, that should be fine.
Matt
Posted on Apr 16, 2008
SOURCE:
How do I connect a Stanton T80 turntable to my PC?
First of all you can try with the line input of your Pc audio card. There will be 3.5 mm stereo socket in the pc audio card (blue color ) which will marked as LINE IN. To connect the turntable to this socket you need a RCA to 3.5mm Stereo converter like on in the picture bellow. I have also added a link to a video which will help you to do the same. In the video the are showing a cassette deck. In you case Turntable in place of cassette deck.
You have to set the switch on the back of your Turntable to LINE OUT. Then you can use any software to record the signals from the LINE INPUT of your PC.
If you need a high quality recording the you have to use a special converter which will do the job neatly.
To convert or upload (copy) tracks in LP in good quality then you need a interface unit between the Turntable an PC. Which will convert the analog audio out to Digital signal ( RCA to USB). The unit will come with the driver for it. That you have to install on your PC.
Keep on thing in Mind that when your are using such a converter between Turntable and PC you have to set the switch on the back of your Turntable to LINEOUT.
Here i have added link which will lead you to such a USB converter. Which will provide you studio quality stereo.
Manual for Stanton T80
Video
RCA TO USB converter
3.5mm STEREO to RCA converter cable.
Ajin
Jul 14, 2012 | Stanton T.80 Turntable
Stanton STR8-100 Turntable ground wire?
There is no such ground points in the Stanton STR8-100. The main thing you have to check is the RCA cable used. You should a high quality RCA cable suitable for Phono connections. If you use a normal RCA cable then it will produce HUM because if its weak ground shield.
Try with a good quality RCA cable with Good ground shielding.
Ajin
Apr 27, 2012 | Stanton STR8-100 Turntable
I have a T62 Stanton and I want to play it like a normal turntable. I conected it in the Behringer mixer using L/R cable. I cannot hear the bass sounds with my headphones. What is happening?
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 17, 2011 | Stanton T62 Turntable
I have lost the cable that connects my stanton c500 deck to the control unit. Could I get a replacement for it and where. Thank you
Hello Max. These connection cables are common items. take the deck to Radio Shack and they will match your device to the necessary cable. Joe
Thanks for choosing Fixya!
Dec 31, 2010 | Stanton C.500 Dual CD Player
Hi, I've had a pair of these awesome decks for over 10 years and one of them has finally developed its first problem. It doesn't output anything to one of the channels (the white plug). I've messed around...
sounds like dodgy internal cabling u need a volt meter to check between cartrigde and main outs also have you checked if you have an output from cartrigde on both channels you will need to swap leads on bak ov cartridge itself but b carefull pins are delicate
Oct 12, 2010 | Stanton STR8-60 Turntable
Stanton rm-3s
make sujre, it is a 1amp power supply
Sep 26, 2009 | Stanton C.304
There's only sound in the left speaker.
when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 24, 2009 | Stanton STR8-30 Turntable
I pluged my american stanton T60X (125V) to 225V. Any solution?
if you can find a fuse or reset switch, replace/reset that first. look around where the power cable enters the device.
if it has no fuse, you've probably cooked the transformer which converts outlet voltage (mains) to whatever the voltage the device is designed to run on. if that's the case, then you'll just need to swap in a transformer that matches the requirements of the deck to the output voltage of whatever country you want to use it in.
if this sounds too daunting and you're not confident with taking electrical stuff apart, go to a shop and get them to sort it for you.
long and short, don't ditch your deck just yet, Chet.
Apr 05, 2009 | Stanton ST-150 Turntable
No sound going through inputs on Stanton RM-3s mixer
ensure that the polarity is not reversed. new power supply about $30.00 on eBay
Nov 05, 2008 | Stanton C.304
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Stanton STR8-60 Turntable Logo
221 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Anthony
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
