I am using Lenovo 3000 G400
There is no screen display when i switch on my laptop. screen display turns on only after 4-5th time, not before that.
please help
Reply at: [email protected]
Is there power when you turn the system On?
In your case it is very difficult to find out which is causing the system not to power, this can be multiple devices on your ssytem.
trying to eliminate one device after another try following the steps below:
>remove the Battery from the system, unhook the adaptor as well then Press and Hold down the power button for 7-10 seconds to drain any power on your motherboard.
>after power draining the system connect the adaptor to your laptop, do not insert the battery yet, Power the system without the battery, if the system turns on leave it turned on for about a minute then shut it down normally.
>insert the battery to the laptop turn the system on if this turns on without any error then your concern is probably ok and fixed.
>but if the system still does not power up having the battery connected to the machine a device on your system can or maybe damaged either the Battery or the Motherboard having an issue with the battery conencted to the machine...
if your system is in warranty call Lenovo and have it sent to teh service center for proper checking and repairs.
i have also problem in my lenovo g400 the same with your problem whn i try to start itsnoting happen but there is no screen display but power led is on pls help us
