Question about Dell Dimension 2400 PC Desktop
Can't get tower cover off
It used to be so easy! What's the trick for removing the tower cover? I need to switch out DVD drives because mine won't open and need to backup files to put on yet a 3rd computer. Your advice will be greatly appreciated!
- Claudia
  • 1 more comment
  • Claudia5 Apr 16, 2008
    Iqbal - Thank you so much - I did figure it out - found it on Dell's website. Decided to just buy a new computer rather than change out the fans and DVD drives and still be stuck with a slow computer! I really appreciate your quick response! - Claudia
  • Anonymous Apr 24, 2008
    How do I get the cover off my Dimension 2400?
  • fbruced Apr 08, 2009
    How do i get the cover off my old dell dimension 4600?
Thanks. Got the cover off. Now got to find the right fan to replace, as the CPU fan is not detected.
Posted on Apr 20, 2008
  • 655 Answers
  • goto dell site
  • get free registration giving your service tag number
  • then search 'how to open cover'
  • You can find video for that
try out and please post your feed-back
Thanks
Iqbal
Posted on Apr 16, 2008
How do I connect a second dvdrw to tower
I connected a second one to mine by just using the install disc that's included and it sets it up as additional drive (example-my second one is drive H) hope this helps your problem
Nov 01, 2017 | Tower Computers & Internet
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
My CD tray will not after removing a fragmented disc that got stuck
It sounds as if there is either still some obstruction within the CD tray mechanism or path, or else the CD drive itself has failed and should be replaced.
I would recommend replacing the CD drive, especially if it has already caused one CD to break into fragments.
Replacing a CD drive should be reasonably easy if you have a tower computer and are happy to open the case.
Depending on the design, there are normally only 2 screws on each side of an optical drive and 2 cables on the rear to disconnect (3 cables if you have a direct sound connection from the drive to the motherboard).
Some case may have a quick release method for removing the optical drive. You should consider replacing the CD drive with a combination CD R/W DVD drive unless you already have a second DVD drive installed.
Jan 17, 2012 | HP Computers & Internet
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
My Phillips DVD 3050V/75 will not eject a DVD - its very low use so can't be worn out. Is there a stick something in to manually eject the DVD trick?
You will need to remove the top cover of this DVD player to remove the disc from the Drive tray. Always unplug the unit before servicing. Be careful to not touch the sensitive electronics. Remove the disc and put the unit back together exactly how you took it apart. There should only be a few screws on the back and sides of unit, holding the case of the unit to the frame and front cover.
May 17, 2011 | Philips DVP3050V/37
I have a 2 in 1 VHS/DVD player. It is a GO VIDEO DV1130. When I press the eject button, nothing happens. The tray doesn't budge. I currently have a DVD in the machine as we speak. The DVD itself works...
Sounds like you've got a problem with either the Drive Motor, Drive Controller or Drive Belt.
It could be an easy fix but it depends on the where the fault is.
Does it make any noise or effort to open the tray?
If yes then its the Drive Belt thats either slipping or broken.
If you remove the top cover and then the cover off the DVD you'll see the drive belt at the front. If it's still in one piece then you can just remove it and get one a few mm smaller.
May 14, 2011 | GoVideo DV1130 DVD Player/VCR
My ACER tower DVD disk tray is stuck.
Considering the low price of a DVD drive, I would just replace it. It sounds like the tray has been bashed, maybe by a leg or object dropped on it?
The emergency hole is likely on the side of the drive inside the case. If you have no experience changing a DVD drive, ask a friend for help. DVD drive installation is covered on the web. It is pretty easy. Just unplug the power first!
Apr 02, 2010 | Microsoft Windows Vista Home Premium with...
Removing current cd/dvd burner from tower to replace with new one can't seem to get it out.acer tower, not real smart with computers sorry
most CDRW drives are secured using 4 screws (2 on each side) which means you have to remove both side plates of the tower to remove the drive, sometimes manufacturers use rails which "clip" the drive in place and are removed via the front instead (sometimes having to remove a retaining screw).
after that the drive is only held in place by the connected cables.
Sep 22, 2008 | Computers & Internet
Acer desktop E500 dvd drive to remove
back? dvd.cd drives usually slide out the front.i think ur try to push a door that u have to pull. rating please. get back if not the solution
Jan 24, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
425 people viewed this question
Alun Cox
