Question about Whirlpool LSR6232J Top Load Washer
Will not let water come into washer.
Are Washer sais style number 4217141 Rev. A. This one quit letting the water come in unless it was on hot or warm, Then it quit working on cold or hot. You can fill the washer with water Yourself, and it will wash and spin and the rest, but water will not come in?
    Genius:
  • 1,073 Answers
Not a good model number but anyway the water inlet valve needs to be replaced
Posted on Apr 16, 2008
Need to know what year is my washing machine?
Date should be on the rating label.
May 05, 2016 | Washing Machines
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
Oct 15, 2013 | Washing Machines
Check the water valve for continuity. Also check the screen on the cold water side to see if it is clogged. That is what I would do.
Oct 05, 2013 | Dryers
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
The hot water doesnt work. Water from supply is there and works but washer will not dispense hot water. I don't know where to find what washer model.
If you switch the machine to the hottest wash and it does not let in hot water then it is usually the hot water inlet valve solenoid that is faulty. You can get these from spares shops, or call a service engineer.
Aug 30, 2009 | Maytag Washing Machines
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is using hot water on the cold/cold was
Unless your hoses are reversed the machine control is bad and needs to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calipso Top Load
lean washer back (if this is top load calypso and not front load as pictured)remove 3 screws along front edge of bottom cover and drop cover if pup is new style remove the 3 torx screws in bottom of pump and clean pump..old style pump just replace unless you can find something in end at hose fitting those old ones were bad about stripping drive splines new style comes with new pump motor
Jun 21, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool LSR6232J Top Load Washer Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal De
