Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Wega 32 tube TV no volume
I have a Wega 32 TV and the volume needs to be on the highest setting just so you can bearly hear it. What need to be checked or replaced
  • richtrix Apr 18, 2008
    I have volume for 2 seconds in between chanels but otherwise no volume. Also I have a no signal and chanel number on the screen. I have bypassed cable and tried a dvd player and it does the same?
  • 71 Answers
How old and what model#??
Posted on Apr 30, 2008
Sony Wega 32in with a volume problem
use it with energy of any shockwave
Jul 11, 2009 | Sony Televison & Video
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problem with 1999 Sony Trinitron Wega 32 inch TV
sounds like the tube has gone any good tv repair shop will be able to replace it cheapley.
Mar 08, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
Can't hear voice/some audio
your audio setting is set to 5.1 and your do not have enough speakers to hear all the sounds. I suggest to change the setting to 2 speakers and you will be able to hear everything. good luck
Apr 03, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Grand Wega 50" LCD
What is model no of your tv, I think, there maybe a modification for it
Nov 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega 32"TV - noise on startup
The slight flash on the screen is usually because the CRT (picture tube) is holding a better than average charge and this is what we call "pre-glow" The noise that you hear, is that everytime you turn it on or just after it has been off for a while? If only after the set has been sitting off for a while then your noise is the internal degauser for the CRT and that noise is 100% normal. The degausers in Sony TV's are so strong they usually make the plastic cabinet vibrate a bit.
Apr 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
