Question about Sony DVP-NS575P DVD Player
The player gives a "cannot play" message for all types of media
After playing 1 DVD and loading a new one, all I get is a "CANNOT PLAY" message.  Reset by unpluging, changed DVD, tried new DVD, tried old (previously played) DVD); I only get a "CANNOT PLAY" message.
  • 8 more comments
  • wiesg Apr 16, 2008
    I fixed it!
    Took cover off (2 side screws, 2 screws on back at the edges, and 1 (different size) screw at the back-top-edge-middle.
    Tried to fix by unplugging unit, loading many different DVDs/CDs, only got "CANNOT PLAY" message.  At times this unit locks-up and I need to unplug it to reset it so that it will run/work.
    With the cover off I could see that the DVD did not spin (easy to see with the cover off), but could hear the head moving/searching.
    Unloaded DVD, reloaded DVD, once the DVD was in spin position, I SPUN THE DVD-CLAMP ASSEMBLY MANUALLY WITH MY FINGER - motor engaged and dvd started playing.
    It's been running fine for 5 DVD tests and 3 compete movies now.
    Just in case the unit locks up again, I only put the one back-center screw back on to hold the lid on.
    Love the player bought it in March 2004 (manufacture date January 16, 2004 (stamped on inside back cover).
    I'll repost if it stops again.
    Greg
  • mikerr1 Jun 12, 2008
    cds play,cdrs play, but store bought dvds do not play. unit flashes loading for a minute or so then [connot play] comes on the screen.
  • marilyn262 Sep 27, 2008
    I have same problem. Unplugged the unit but it did not help.
  • Anonymous Sep 28, 2008
    had the same problem and solved it the same way - only 1 year old too.
  • brotherdave8 Jan 25, 2009
    Where is the best place to get a spin motor for these players?
  • slverbulet7 Mar 10, 2009
    Same problem. I bought it only a year ago, so I did not suspect something was wrong with the player. My first thought was dust on the reader, but I wasn't able to get to it to clean it. I can't get anything inside to move; it's all connected to too much to risk.
  • snerix4al Mar 25, 2009
    my player can accept cd's but its displays 'cannot play' messsage while using dvd...but my dvd is spinning
  • Anonymous Apr 07, 2009
    Brilliant, Greg, this is exactly the fix I needed. My unit is relatively new and relatively little used but had the same symptoms and this solution saves me either a repair bill or a new unit (both would probably cost the same).
    But it makes you think that those extended warranties might not be such a bad idea, after all, considering the poor design/build quality of so much stuff these days.
    Brilliant fix, Greg; I had the same problem and this has fixed it, for now, saving me the cost of a repair or new player.
    But it makes you think that those extended warranties might not be such a bad idea after all, considering the sometimes poor design/build quality of so much stuff these days.
  • vafrank Apr 07, 2009
    Brilliant, Greg; I had the same symptoms with my relatively new and relatively little used unit, and your method works for me, at least for now. Saves me a repair bill or the cost of buying a new player.
    But it makes you think that those extended warranties aren't such a bad idea after all, considering the oftentimes poor design/build quality of so much stuff these days.
    New Friend:
The motors are trash. Just by a Samsung; the repairs of player does not justify fix.
Posted on Nov 08, 2014
Unit probably has a defective disk motor that is in border line failure. When problem again arises, have the motor replaced
Posted on Aug 15, 2008
SOURCE:
A number of qued files are stopping windows midia player from playing dvd,s
Some DVD copies use different compression codes.
check files by loading on a computer (do not auto play)
view folder on DVD then view file detail see if compatible file types with your system...
Dec 06, 2013 | Computers & Internet
My media player want play dvd's
Maybe your screen resolution needs to be higher? What type of error message are you getting? Are these dvd's that you were able to play before?
Most computers will have problems playing dvd's that someone made for you on their computer. Try a store purchased dvd and see if it plays.
You can always reinstall windows media player at Microsoft's site below.
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
You can also try the VLC Player. It comes with drivers and codec. I've seen it solve a lot of issues that Media Player could not fix.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
May 11, 2012 | Everex eXplora RS2800 PC Desktop
Will not play dvds
LOL, wow that's an oddity, normally it's the other way around where it plays store bought but not burned. Make sure you are not trying to play Blue Ray in a Regular DvD Player.
Oh, one more real important point. If you're using Windows Media Player as the player, that might be your problem. Media Player cannot handle all types of media devices and sometimes they don't give you a message saying anything because it just don't recognize a disc is even in the drive.
Go to www.google.com and in the search box type "Download VLC Player" (without the quotes). Look for the site www.videolan.org/vlc in the search results and click it. That's where you want to download it from. VLC is an open source player that will play any type of video format. It is far greater than Windows Media Player. It installs in less than 3 minutes and it is fast and smooth. You'll love it. After you install it put your cd in the drive and you will probably be prompted as to which player to play it with. Click VLC. If VLC is not shown as one of the listed players chose the option to browse to chose it. Now after all this, if you still can't play the dvd, then your drive is faulty.
Mar 20, 2012 | Computers & Internet
Player won't play legally imported DVD's
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Jul 20, 2009 | Electronics - Others
My DVR-110D does not play DVD's it says MPEG-2 encoding/decoding is not available
email me at billfox1966@yahoo.com and be more specific as to wether or not thats a popup message or the media player is telling you that. if its the media player, then you might try going to www.freedownloads.com and type in the search area (codec pack) then download that and install it. then at the same site load a media player thats called (media player classic) these 2 installs combined should play any type of dvd one the market without fail. if you need any further assistance please feel free to mail me. bill fox
Jul 08, 2009 | Pioneer DVR-107D DVD±RW Burner
When i load the dvd player on my laptop with a movie it will not play or autoplay the message: THIS APPLICATION WIIL NOT PLAY THIS DVD BECAUSE OF THE CONFIGURATION OF THE OUTPUT DISPLAY PLEASE RESTART YOUR...
The output display is your monitor. You may need to change the resolution of your minitor. Change it back to default settings. Also try a new program to play your dvd such as VLC media player or Gom Player. Bother are available off http://download.cnet.com/windows/ Hope this helps. Can u rate me if it does.
Jun 23, 2009 | Dell Vostro 1500 Notebook
Playing a dvd with an hpr extension
Why don't you try to play the cd with a different type of media player....?Why don't you try media player classic or Windows sound recorder.... When I get this type of prob. I use VLC media player...
Jan 06, 2008 | Adobe Photoshop 7.0 for PC
Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
Jun 29, 2007 | Panasonic PVD4744 DVD Player/VCR
Sony DVP-NS575P DVD Player Logo
619 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
