Frigidaire top load washer FWS933FS not filling
On large load washer does not seem to be filling all the way. It stops filling about 4 inches from ring - old washer filled much higher - only using cold water, could that have something to do with it???
    Genius:
  • 1,073 Answers
Cold water has nothing to do with the water level this is the normal level for this machine
Posted on Apr 16, 2008
Frigidaire Top Load Washer Model # FW933FS2, when starting a load of laundry it begins to agitate but no water enters the drum. What do I need to fix this problem?
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
Dec 15, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
When I wash clothes the water level is always too low. It's almost like I have to do half loads or sit there holding the reset until it fills up all the way. Is there anyway to adjust that? It's a...
there is a unit in the top called a water level indecator it can be adjusted but if its working this bad i would replace it there not expensive
May 05, 2011 | Washing Machines
Frigidaire top load washer model number FWS6600ES0: during the wash and rinse cycles... whether it's filling or agitating on either... water seems to be draining causing the machine to stop and start...
If it has detected SUDs it may be trying to rid them. Is your drain hose at least 30 inchs above the floor? If is ain't then gravity may be causing the problem. Is the drain hose jammed tightly into the drain? This may cause a siphoning effect.
Oct 29, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
May 02, 2008 | Frigidaire FWTBB30DS Front Load Washer
Not filling up completely
four inchs under rim is right level any more and it would leak
Nov 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washer will not fill up completely
  • The drain standpipe is too short.
    To prevent siphoning, the standpipe must be at least 33 inches high for a top load washer or 24 inches high for a tumble action washer. Refer to the installation instructions that came with your washer for more information.
  • Drain hose fits too tightly in the standpipe causing siphoning.
    There must be an air gap between the drain hose and the standpipe to prevent siphoning action. The standpipe needs to be at least 1 1/4 inches in diameter.
Oct 18, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
