Question about HP 5590 ScanJet Flatbed Scanner
HP ScanJet 5590 ADF doesn't engage
Everytime I place a document in the ADF and scan, the first time it doesn't pull the paper from the ADF and I receive a blank document. If I go back through, and follow the same steps again, it then pulls from the ADF and scans correctly. Any suggestions?
  • jheyde Apr 25, 2008
    The PC is running XP SP2.
Cannot possible to install in vista using the CD of scanjet 5590
Posted on Apr 25, 2008
I get a red line down one side of the page when scanning using the adf on a HP 5590 scanner
My guess is the ADF has picked up some dirt. Check the path very carefully.
Nov 04, 2011 | HP Scanjet 5590 Flatbed Scanner
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
Install feed rollers in ADF of HP scanjet 5590
You can get a service manual at this website address (HP website):
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Scanjet+Scanner&qry=instruction+manual&submit.x=7&submit.y=4&ctry=emea_africa&lc=en&dlc=en&mode=fb&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
Feb 06, 2009 | HP 5590 ScanJet Flatbed Scanner
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Aug 18, 2008 | HP Scanjet 5590 Flatbed Scanner
ADF
1- reinstall drivers
2- Use the WIA driver for Windows OpSys
3- Pay close attention to options in dialog box. Select ADF or Document Feeder as an option
4- Depending on the OCR application [personally I prefer PaperPort] the imaging process can be very eaasy or somewhat difficult
Jun 02, 2008 | HP Scanjet 5590 Flatbed Scanner
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
HP 5590 ScanJet Flatbed Scanner Logo
1,191 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
