Question about Kyocera Office Equipment & Supplies
Transmit/Receive Error (0x3101) - Kyocera Office Equipment & Supplies
I have the same issue, how did you solved it?
Posted on Nov 22, 2011
If you can print to the KM, you know the network connection to the machine is fine.
I'd try using the IP address of the exchange server first. If this fixes it, check the DNS settings in the copier.
If that doesn't work, try running 'telnet exchangeserverName 25' from a command prompt on a nearby computer. You should see something like '220 exchangeserverDNSname ESMTP' as a response if it connects. If this works, I'd start with checking the gateway settings on the copier.
If it doesn't connect, there's no usable SMTP server on that port.
Posted on May 19, 2010
Kenwood Protalk tk-3200U8P will receive, but not transmit. When talk button is push a loud beep will sound. Any suggestions?
Assuming it is programmed correctly, it is a weak, undercharged or bad battery. Transmit takes a lot more power than receive. A beep or no transmit, even if the Transmit light comes on can still mean the battery condition described.
Feb 11, 2015 | Kenwood Radio Communications
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
I am able to transmit but not receive
get another that only receives and no transmit.hook them up together .one on top of the other .I have a friend that did this and it actually worked
May 30, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Comm error 252
The comm error 252 occurs due to,
  • Telephone line conditions were too poor to receive a fax.
This error can be rectified by
  1. Reattempt the fax reception at a later time when line conditions may have improved.
  2. Configure the machine to start reception at a lower speed.
  3. If the local machine successfully received several pages of a larger document, ask the remote user to transmit the document in several smaller parts.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 15, 2009 | HP LaserJet 3050 All-In-One Printer
Get communication problems when sending some faxes - when sending faxes to some places it won't transmit but will transmit to other places
The problem can be either a error with your phone service or an incompatablity with your machine and the receivers.
Sometimes the problem is as simple as the receiver's machine being set to receive on more rings than your's before it goes into redial.
Apr 15, 2009 | Office Equipment & Supplies
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
0x3101 error on kyocera when trying to send scan to email
you can not scan usb, it has to scan via network cable via the scan card . you can use quicksetup utility to log in to the scan card and change the destination ip address of your tower. as long as your tower has a static IP sddress , should be applied via web interface of the scan card..
Nov 02, 2008 | Kyocera Office Equipment & Supplies
8,410 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
