Question about Sharp AL-1642CS Copier
AL-1642CS When I attempt to make multiple copies, I get two vertical lines down the page. This does not happen when doing single copies. I have changed the Toner Cartridge and Drum. Solution? Thanks.
    Problem Solver:
  • 5 Answers
Dirty main charger it is located on the drum unit remove and clean or replace the wole drum unit
Posted on May 29, 2008
  • 29 Answers
Try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Posted on Apr 21, 2008
I have a sharp AL 1642cs and every time I make copies from the top of the printer my copy comes out with line/strips. What can I do not to get those lines anymore.
The machine that you have is digital the scanglass has somethind on it clean it with windex or alchohol that should take care of it
Jan 27, 2011 | Sharp AL-1642CS Copier
Vertical lines on copied page
Run a copy on the glass if there are no lines then something is on the scan glass of the document feeder. Use some window cleaner and scrub the document feeder glass and test. Sometimes white out or ink will stick to the glass and the scanner reads the dot as a line.
Sep 08, 2010 | Sharp AL-1642CS Copier
Sharp al-1642cs-lines on copies when you use the spf
you should clean the thin glass(it is about 2cm wide) under the spf.
Jun 21, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL-1631. The single copies made face down on the glass are fine. The multiple copies made on the automatic feeder have vertical lines running through them. Can you please assist me.
This is caused by the adf scan glass needing to be cleaned. If you look just to the left of the large glass you will see a thin strip of glass encased in plastic. You need to clean this glass. It may look clean but this glass is only used when using the feeder and sometimes any ink spots or dirt are not visible. If you only get the lines when using the feeder the problem is on this strip of glass.
Dec 02, 2009 | Office Equipment & Supplies
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS
Hello sir; I believe that's drum cartridge problem try to change that see what going to happen.
Jan 22, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Vertical lines on multiple page copying
Did you check to see if the lines are before or after the fixing unit? Stop a copy before it gets to the fixing unit. If there is no lines in the same spot, then the problem is in the fixing unit, if not check the and clean the optics and dust proof glass. Good Luck...
Apr 16, 2008 | Sharp AL-1642CS Copier
Lines on copys when i feed through top feeder
There is a small strip of glass under the feeder.Not the main glass, but look where the lamp is sittting in the start position.
You have something on that section of glass.
It may be very tiny, but that is what causes that. Best way I have found to get that clean is with some alcohol and just a plain piece of copy paper crumpled and used as your cleaning towel.
The reason it is there only when you copy through the feeder is this. When you copy off the glass, the lamp moves and scans the original end to end. So a spot is simply a spot.
When you run through the feeder, the lamp parks and the document passes over the lamp scanning that way. So any mark between the lamp and document will repeat and be line down the page.
Mar 28, 2008 | Sharp AL-1642CS Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
