Question about Sharp Aquos LC-20B2U 20 in. LCD Television
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
    Sergeant:
  • 280 Answers
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Posted on Jul 10, 2008
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Blowing fuses
make sure fuses are setted tight
check for signal bulbs could be bad.
i had a case where filiment in bulb had come into.
it was shorting the bulb out
Aug 05, 2014 | kawasaki VN 1500 Vulcan Classic...
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
2003 chevy s10 - keeps blowing out AC fuse. Will work for a couple minutes then compressor quits working. Check the fuse, it is blown out. Put in a new fuse, works a couple minutes, then quits, fuse blown...
Unplug the a/c compressor, there will be a plug near the pulley. Install a new fuse. Start the vehicle and turn the a/c on. Wait about the same amount of time it took for the fuse to blow in the past. Did the cues blow? If no replace the a/c compressor, the clutch has gone bad. If yes, than the wiring between the fuse and the relay or the relay to the comps sore is grounded. A careful inspection of the wiring should reveal the problem.
Jul 03, 2011 | 2003 Chevrolet S-10
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a 2001 Ford Escape and recently it has been blowing both the break light and hazard/flashers fuses. It started with the break light fuse leaving me stranded in a drive through for an hour because I...
There is a shorted wire in somewhere in the circuit. The problem is where. You can use an ohmmeter and trace all your wiring or use a voltmeter and find a light socket that doesn't measure up to the rest or has inconsistent voltage readings. Make sure the fuse is not smaller than the origional
Dec 09, 2009 | 2001 Ford Escape
Sharp LC20B2UA; Blows fuse F3701.
Check the primary side of T3701 circuitry, Q3700 and S4701 for shorted condition.
Feb 28, 2008 | Televison & Video
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
366 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
