Question about Denon AVR-2805 Receiver
No output After 3 years of heavy usage, my AVR 2805 now gives only intermittent audio output.  For the past several days, whenever I turn it on, it will  not output any audio for TV, DVD, VCR or even the tuner.  I've checked all the settings and the input is set to automatic.  If I turn the receiver on and off several times, sometimes the audio comes back.  If it does come back on, whenever I turn it off, the next time I go turn it on, there's no audio.   I am using optical cables for the DVD and the satellite TV.  Any suggestions? denon avr-2805 no output on any of the outputs
  • giol Apr 25, 2008
    no I do not any click from a relay.I know that the amp made a loud humming noise before the sound went dead.after that all outputs no longer worked.
  • 563 Answers
Hi giol
This is normally an IC or two that has gone due to either poor soldering or ageing.
I wouldn't recommend you try and fix this by yourself. Rather take it to a Service Centre.
Posted on Apr 25, 2008
  • Marnus Jacobs
    Marnus Jacobs Apr 25, 2008
    giol
    If you do however decide to investigate this problem on your own , leave the AMP for at least 2 hours switched off before you even think of opening it.
    Once you've got the cover off , you will be looking for the board with all your outputs on it. Check for any black markings on the soldering.
    If you cannot see any marks , plug in the AC and try checking for any irregularity on the board.
  • 3,037 Answers
Well, you can open it up and look for anything that looks fried a little or loose. Make sure you have it unplugged when you do this and you will be fine.
Maybe a gentle shake will show you what might be loose or broken.
Otherwise something might just be on the verge of burning out totally. Have a look and let me know what you find.
Thanks
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • 4,234 Answers
I have seen a number of these with similar symptoms. Usually it is caused by poor solder connections. This is due to heat cycles and is normal. If this one follows the pattern, the repair would entail resoldering the voltage regulator circuit and perhaps the driver circuit.
Dan
Posted on Apr 16, 2008
  • ABRsvcs Apr 24, 2008
    For what it is worth, there are no erlays for switching the inputs, this is handled by electronic switching chips. There will be no relay action when changing inputs. There should be a relay click on turn on as the output section is engaged.
    Dan
    Master:
  • 788 Answers
Probably a input switching relay problem. When you switch inputs you should here the click of a relay, do you hear that click?
  • Dean Joly
    Dean Joly Apr 28, 2008
    Ok, sounds like there is an electronic fault inside. Did you open it up to look at the components? Look for anything that looks burnt, leaking, loose, or broken.
Avr 2805 only works on direct mode
You have a problem with your DSP circuit. Unless you are good at reading schematics and using DVM's and soldering, then you need to take it to a servicer.
May 16, 2012 | Denon AVR-2805 Receiver
My remote of AVR 2805 (RC-974) is lost . After check of Dealer in thailand they told me RC-974 discontinue .Please suggest the other model of remote can use with AV-2805 . I think RC-1030 can use with AVR...
..or you could buy a universal remote, like Logitech Harmony xx. Denon also makes a universal remote, but it is pretty expensive and not as easy to program as the Harmony.
Mar 05, 2010 | Denon AVR-2805 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
Jan 16, 2010 | Denon AVR-2805 Receiver
My Denon AVR 2805,has a problem. In a few seconds after switching on, it automatically turns itself off. What is the cause of this problem? How can I fix it?
This unit is in what is termed :protect mode". This means that one or more of the amplifier channels has a rpoblem that was detected by the protection circuit inside and the unit has been shutdown to prevent further damage. This is often shorted output transistors or a defective amp pac for the surround channels. Expect a parts cost in the $50 range for this repair.
Dan
Oct 08, 2009 | Denon AVR-2805 Receiver
How do I connect my Apple ipod to my Denon receiver:AVR-2805/985?
GET A CONECTION THATS RCA CABLES IN ONE ENND AND HEAD PHONE JACK INTHE OTHER AND CONNECT THE RCA CABLES TO UR INUTS AND THE HEADPHONE JACK TO UR IPOD AND START PLAYING
Jul 01, 2009 | Denon AVR-2805 Receiver
Receiver turns off in a few secondsafter switching on
read in the manual and reset the system. if it still doesnt turn on, then it has to be taken in for repair. same thing happened to mine
Apr 25, 2009 | Denon AVR-2805 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
No output
I have this same problem, I took my unit to a Denon authorized repair center and after 12 days and $50 to check out the problem they have told me that my DSP was bad and that Denon no longer makes that part. For a unit that about 2years old and no parts???
any help would be appreciated.
Nov 12, 2007 | Denon AVR-2805 Receiver
Intermittent audio output
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Sep 10, 2007 | Denon AVR-3300 Receiver
Denon AVR-2805 Receiver Logo
206 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
