Question about Cook's Essentials CEFB2B
Cooks coffee pot stopped working
I bought a new cooks coffee pot from J.C. pennys a few weeks ago, it worked great until one day I turned it on and the light came on an usual, but then nothing happened...did not pull up the water or get hot.
  • 3 more comments
  • bigginag Nov 22, 2008
    Same here worked great til today. turned it on lights came on and nothing! no brewing no warming nothing.What do I do?
  • Anonymous Nov 25, 2008
    I had the exact same issue same machine, also bought it at JCPenny and the coffee maker is less than a week old! And they won't take it back because I didnt' keep the box it came in.
  • Anonymous Dec 06, 2008
    will not pull up the water! the light is on...the coffee is not!
  • billsmrs Feb 19, 2009
    Same exact problem.... came in one day to work and noticed the coffee wasn't brewing and when I went to check on it the light was on but there was no warming and no coffee being made. So aggravating!!!
  • kehoe234 Apr 16, 2009
    I have the exact same problem. I plug it in, the light goes on but nothing showes in the display. No brewing....nothing. I can't find a replacement part and I love this coffee pot. It looks so classy on the counter. It worked great and then. POOF.........done.
    Now what?
    I called the company and they said to contact JC PENNEYs, well I have no reciept or box......I guess I'm out a coffee pot!
I bought the coffee/espresso maker. The espresso side still works, but the coffee side does nothing. I only had used it for about a week, but that was long enough for me to throw the box. I was going to contact the company but I see that will do no good, so my suggestion is to buy a new one (same exact model) then put the broken one in the box and return it. You will have a new coffee pot, and you won't be out anymore money.
Posted on Aug 01, 2009
Not sure of my model cooks as it did not come with a box. I did find it wanted to heat the water but would not come up through the straw and out the holes and into the coffee pot. Instead it heated the wter right out of the coffee maker and onto the counter. I decided towatch it and thestraw mechanism was at fault. I took it out and ran water up the straw from the sink and found it coming out the end of the black piece insteadof through the holes like it is supposed to. I tapped it on the counter and a small bead like piece came outthatwas to seat properly at the end of the tube where you slide the straw into the hole dripper. I sealed the hole and wahla I got a great coffee maker that the water comes out the brewing holes. look to see what yours is doing while heating. Is it making a bunch of loud popping noise and water heating but not going into the pot. Give this a try if you cant return your pot..... Now for glass carafs. Go directly to the maker of cooks. Not JC Pennys. They are just the outlet that sells them. Google it on line. I havent fdone that yet. Get them to give you and order form on line and a way to secure your payment for your caraf replacement. Check it at the door when it arrives and dont let UPSor whoever dropped it off to leave till tyou have looked at it to make sure it has no cracks or broken pieces.
Posted on Feb 10, 2012
How do I replace the glass coffee pot ?
Posted on May 04, 2008
Cuisinart coffee pot
his EXACT situation happened to me 2 days ago because it gets clogged. Flush and dump clear HOT water threw the tank several times. When I did this, clumps of coffee came out and the coffee maker worked great again. In hindsight..it was my bad because the manufacturers say to run a clear vinegar flush threw them once every 6 months, followed by 2-3 clear water flushes to remove these "clots" that plug it up. Hope this info is not too late and you didn\'t throw your machine out. :)
May 07, 2013 | Coffee Makers & Espresso Machines
Coffee pot turns stops brewing in the middle of the cycle
If this is not an electrical problem, try the following:
Try running a cup of WHITE vinegar (of course without the coffee), this will clear out anything on the path.
Once you do this, run 5 cups of plain water (again without coffee) twice to clear out any vinegar flavor from the path.
Feb 01, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
NEW '' Cooks'' coffee pot quit working after 2 days
HI try finding cooks on google and send them the serial number they might exchange it for you
Jan 28, 2010 | Cook's Essentials Cooks Essentials Arome...
Our 55 cup coffee pot broke, it has a one year warrentee, it is from JC Penny's home collection. How do I go about getting it replaced or fixed.
Go to where you get your 55 cup coffee pot and have their assistance regarding waranty replacement or
fixing it. Send your e-mail comments
Oct 07, 2009 | Cook's Essentials Cooks Essentials Arome...
Coffee maker will not power on at all
Take it back to the seller for warranty replacement.
Aug 01, 2009 | Coffee Makers & Espresso Machines
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Clean button keeps blinking
Unplug the coffeemaker for one hour, and the self-clean light should come off.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DCC-2000
Keurig B60 makes coffee at random all by itself
Try plugging it into another outlet, preferably one on a different circuit breaker. If this works call an electrician. I have seen electronic devices do all sorts of strange things when the power is bad.
Mar 02, 2017 | Keurig B60 Coffee Maker
Coffee pot
As long ago as you posted this, the unit has a 3-year warranty - call Cuisinart and redeem it.
Jul 24, 2008 | Cuisinart Thermal DGB-600 Grinder
Open Questions:
See all Cook's Essentials CEFB2B Questions
Coffee Makers & Espresso Machines Logo
2,755 people viewed this question
Top Cook's Essentials Coffee Makers & Espresso Machines Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Robert Plante
Are you a Cook's Essentials Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
