Question about Refrigerators
Hometics Envira Station DWS-150 Weather station
I need the manual for the Hometics Envira Station DWS-150 Weather station. Would you be able to email the pdf file that you have to me?
I would really appreciate it. Thanks,Lee
2 Suggested Answers
SOURCE: Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Posted on Apr 16, 2008
LA Crosse manual for weather station 308-1414
Most LaCrosse weather station manuals are available here: http://www.meade.com/support/manuals/ or on the product page (see the Support tab). Using the search feature on the support page, I found three models which start 308-1414. Two of these differ in the color of the case of the weather station. Hover over the picture of any of these weather stations and click on the More button to go to their product page. The direct link to the manual for the 308-1414MB is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414m.pdf . This product page is http://www.lacrossetechnology.com/308-1414mb-weather-station/ . The manual for the 308-1414W/308-1414B is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414.pdf . The product page for the 308-1414W is http://www.lacrossetechnology.com/308-1414w-weather-station/ .
I hope this helps.
Jul 10, 2017 | La Crosse Measuring Tools & Sensors
How to make the outdoor temp work on an Envira Station
Change the batteries in both units. Although the display will be looking fine, the unit uses wireless transmitter and receiver to collect the data and needs full battery power.
Envira Station Google Search
Jul 03, 2017 | Measuring Tools & Sensors
I cannot find the owners manual to hometics envirastation dws-400 weather station, and need to know how to synchronize the outdoor temperature sensor with the indoor station readout (i.e. pressing what...
You must remove the batteries in the base unit, replace them, and it should work properly. You can press the Tx button on the back of the remote unit to verify the RF reception. To ensure it is working properly, place both units next to each other indoors and make sure they read the same temperature.
The manual can be found here. Refer to page 3 for more information.
May 03, 2011 | Health & Beauty
Need instruction manual for EnviraStation DWS-110. Basically cannot get wireless to transmit to inside unit. Have new batteries in both units. Pls advise.
Here is a ink for the manual
http://www.simaproducts.com/support/files/FW_101_user_manual.pdf
You will need the free Adobe reader to open the file: http://get.adobe.com/reader/
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 06, 2011 | First Alert FWS-101 Wireless RF Weather...
Set the clock
7
SETTING TIME
appliances, TV etc.
TIME ZONE SELECTION
display).
to confirm.
Mar 17, 2008 | Refrigerators
Refrigerators Logo
715 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
