Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool ice dispenser not working
My ice dispenser will not work when activated the dispenser door activates but nothing happens
Ice depenser in the door does not work. Moved it and had to take the doors off. It is a 5 button and only the 2 buttons related to the ice don't work.
  • 1 more comment
  • Jerrybug Jun 07, 2008
    My refrigerator will not dispense ice from the face of the door. Water dispenser works fine as well as the ice maker. I believe that I have a faulty ice dispenser switch since the auger motor was bench tested and works fine. How do you remove the face plate to the ice/water dispenser on the out side of the refrigerator so that I can test the ice dispenser switch?
  • whiteislandg Mar 13, 2009
    makes ice but will not dispense ice from door..the trap door opens but no sound of motor running. model GS6SHAXT03..manufactured 10/02
  • tonioli Mar 15, 2009
    I am having the same problem, ice maker not putting ice in reservior. Purchased this refrigator in 2004 for almost $1500.00 at home depot. Very dissappointd in this product. Doors don't
    stay all the way open for easy access either.
  • 184 Answers
Posted on Apr 16, 2008
  • Dick Reishus Jul 10, 2012
    My ice make is making ice but it will not dispense it from the container out through the door. My water works fine on the door. What should I do?
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Nov 27, 2014 | Refrigerators
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker stopped working, still get water to dispenser. fan works, don't know whatelse to check?
If your freezer is working, and water is reaching the ice fins/tray; check that the metal wire lever is in the down position for dispensing water and/or up for when ice is ready. The lever activates a small valve that allows water to drip onto the ice fins/tray...
Jan 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator by itself activates the water or ice dispensing
could be the water valve or water switch (depense switch)
Apr 01, 2009 | Refrigerators
Whirlpool GS6SHAXMB00 ice dispenser not working
remove the ice bin close door and push for ice and hear if the motor working if motor not could be door switch if motor working is the solideo valve
Mar 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
motor drive shut down/reset if their is available
Dec 31, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
531 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
