Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
C000221 I was installing Xp sp2 on a freshly formated harddrive and an error screen appears c000221 unknown hard error system 32 / systemroot /ntdll.dll
Try installing a previous operating system I used windows 2000 and then upgraded to XP and it worked without the error message
Posted on May 12, 2008
  • 4 Answers
Change the operating system cd try again change ur ram with any other ram from ur friends and try thats it ur probelm gets solevd in one of the cases try them gud luck
Posted on Apr 16, 2008
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Error code C000221 unknown hard error\system
Do these errors appear at system start up?
Did you recently install any programs?
If you did, uninstall the program, that should solve the problem.
If you didn't install any program before the error messages, perform a system restore.
Dec 30, 2009 | Computers & Internet
When i start my computer i get this message: stop: c0000221 UNKNOWN HARD ERROR /SYSTEMROOT/SYSTEM32/NTDLL.DLL what can i do?
I have a wipro laptop. i install windows Xp .But my system could show the operating system error . Then I am reinstalled Windows Xp. But the system will turnoff.
Dec 16, 2009 | Acer Aspire 5050-3242 Notebook
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Hard error : STOP C000021
This is a common error
just copy or download ntdll.dll file from the net and replace the file in ur disc
then just make a new bootable iso file and burn into a new cd
restart the comp,install and enjoy
Shreyas
Cheers
Feb 19, 2009 | Microsoft Windows XP Professional for PC
C0000221 Unknown Hard Error\System32\ntdll.dll
From MS's KB:
http://support.microsoft.com/kb/314474
Feb 06, 2009 | Microsoft Office Professional 2007 Full...
Unknown Hard Error
It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
Illustrated procedures located here
Aug 26, 2008 | ASUS P4VP-MX Motherboard
Windows xp installation
HI,
Here is what the Media test failure check cable eiting PXE ROM means:
Iam sure when we were changing some settings with the BIOS you must have done something wrong.Just reemember if you changed some settings over there.
try change the boot-order in the BIOS
try to disable "network-boot" in the BIOS.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue,Isuggest you go through the steps in document CH000229 relating to a similar error message.
Now coming to System32\ntall.dll unknown hard error:
Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
If the ntdll.dll error only displays when you use a specific software program, uninstall the program, reboot your computer, and then install the latest version again from scratch.
Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Perform a repair installation of Windows XP. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file. Remember to install all Windows service packs and other patches after this installation.
Perform a clean installation of Windows XP. A clean installation will completely remove Windows XP from your PC and install it again from scratch. I don't recommend this step unless you have stepped through all previous troubleshooting steps and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2). NOTE:a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive. If so, replace the hard drive and then perform a new installation of Windows XP.
Apr 20, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
764 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
