Question about RIM BlackBerry Pearl 8100
Got a psp cant get music and pictures to work on it with memory card thanks
    Sergeant:
    Champion:
  • 304 Answers
  • Check that the media is inserted correctly.
  • If the storage media is formatted (initialized) on a PC, the PLAYSTATION®3 may not recognize it. After copying the required data to a PC, try reformatting the media on the PLAYSTATION®3.
  • There may be a problem with the media in use. Try using another media that is compatible with the PLAYSTATION®3.
  • Some media may have region or territorial restrictions and may not work with your system. See media packaging for details.
  • Use of certain storage media are available only on the PLAYSTATION®3 60GB model.
Posted on Apr 16, 2008
I cant get what i put on my memory card to show up on my psp
This is a problem occurring in all the playstation 3 consoles....... this is mainly because of the poor quality of thedisc.....as a result it leads to the damage of ur PS3 lens..............usegood original discs........the heating effect is due to the long usage ofpirated discs ...
check your lens if its working good then betterdownload this Repair Guide for further information .........
CLICK HERE to download
May 17, 2010 | Sony PlayStation Portable (PSP) Slim...
8gb memory card corrupted.
If its cost a lot, it should have warranty. Go and ask for a replace. 7.63 GB is ok for a 8 GB card. cz, file system itself takes some space.
But i dont think the card is still good.
Oct 09, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My music doesnt work when i sync it to my psp..how do i put music on my psp?
You must have a memory stick in your PSP to add music or pictures to it.
When I connect my PSP to my computer with USB or pull the memory stick out and stick it in a card reader, I can copy music directly into the (drive letter):\MUSIC directory. Then when I disconnect the PSP or reinsert the memory card into it, the music is there to play.
Sep 18, 2009 | Sony PlayStation Portable (PSP) Console
Memory card formatt refusal
If you have a memory card and it is not being recognized it may be damaged. If you formatted your psp, I am affraid you music is gone my friend. Formating erases all data.
Jul 01, 2009 | Sony Audio Players & Recorders
Our computer cant access our psp memory card
fe4875a.jpg Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PSP uses Sony Memory Stick Pro Duo and you need an adaptor (see picture) to use it on your external card reader or your laptop’s built-in card reader. Also, please check your card reader if it supports Memory Stick Pro Duo.
If you already have an adaptor but still doesn’t work, you can buy a PSP USB data cable to transfer files between your computer and PSP.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Psp malfunctioned...
maybe try n format the memory card.
Sep 15, 2008 | Sony PlayStation Portable (PSP) Console
Transfering pictures to psp
you can drag and drop using windows explorer when its connected to pc but make sure the folder is named exactly how it says in your psp book or the music wont work.
Jun 23, 2008 | Sony PlayStation Portable (PSP) Console
HOW CAN I UNLOCK MY PSP???
Well if u have time, start 0001, 0002, 0003, etc up til 9999 and u will eventually unlock the code.
Apr 02, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
RIM BlackBerry  Pearl  8100 Logo
23 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
