Question about Dryers
Whirpool estate dryer teds680eq2 does NOTHING when start button is pushed.
    Novelist:
  • 184 Answers
NO POWER CAN BE A MULTITUDE OF PROBLEMS.
1 DOOR SWITCH 2. THERMAL FUSE. 3 MOTOR 4. TIMER
5. HOUSEHOLD VOLTAGE. 6. PUSH TO START SWITCH.
CHECK ITEMS IN THE ORDER LISTED.
THE DOOR SWITCH HAS AN ARM THAT EXTENDS DOWN INTO THE SPACE WHERE THE DOOR CLOSES. IT IS LOCATED IN THE UPPER RIGHT CORNER. PRESS IT WITH YOUR FINGER TO SEE IF IT CLICKS. THEN CLOSE THE DOOR AND SEE IF IT CLICKS WHEN THE DOOR SHUTS.
IF NO CLICK, REPLACE THE SWITCH.
THE THERMAL FUSE IS LOCATED BEHIND THE LOWER BACK PANEL OF THE DRYER DOWN BE THE EXHAUST. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED.
JUMPER ACROSS THE TWO WIRES. PUSH THE START BUTTON. IF THE DRYER COMES ON, REPLACE THE THERMAL FUSE AND CHECK FOR PROPER OPERATING TEMPS.APPROX 160-175DEGREES FAHRENHEIT.
IF IT GOES BEYOND 220 DEGREES, REPLACE THE CYCLING THERMOSTAT LOCATED BESIDE THE THERMAL FUSE.
THE OTHER ITEMS SUGGESTED ARE MORE IN DEPTH AND REQUIRE A KNOWLEDGE OF READING SCHEMATICS.
Posted on Apr 16, 2008
My Estate dryer won't turn on. I push the on
See if the lever on the door switch clicks. You cannot hear a click or the lever is missing that could be the problem. On the backsides of the dryer is a dust cover. Remove it and look for reasons why the duct fuse might melt and kill power to the door switch.
See the lever there? That must be in for the door circuit to activate the motor.
Manual and more HERE
Sep 08, 2011 | Estate EED4400WQ Dryer
TEDS680EQ2 estate dryer. I need directions on how to change a 4 prong plug to a 3 prong
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 25, 2010 | Estate TEDX640JQ Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
305 people viewed this question
Top Dryers Experts
