Dell XPS M1530 Laptop Logo
Posted on Jun 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell xps error code 2000-0141 and i run dell systems check and rogram cant no find my hard drive and is beeping few times when i restart any body know the best way to know if is hard drive problem or ?
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Jul 05, 2010
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404494
Points
12062
Reseat the Hard drive, see if anything changes
Hard disk drive failure, you will need a replacement hard drive.
Why wont my xps 700 boot?
Not sure on the beep side but this is what the lights code refer too.
Ensure that all hard drive and CD/DVD drive cables are properly connected to the system board.
If there is an error message on the screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
If the operating system is attempting to boot from a device (such as the floppy drive or CD/DVD drive); check system setup to ensure the boot sequence is correct for the devices installed on your computer.
If the problem persists, contact Dell (see "Contacting Dell" in your Owner's Manual).
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
5helpful
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
1helpful
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Dell xps 1330 is not getting booted, when run the diagnostics got Error 2000-0146. After restart with repair got blue screen with error STOP: c000135, Please help me to resolve this issue.
Resolution is simple enough. 2000-0146 is a read-write failure of the hard disk drive. You will need to replace the drive and reinstall Windows and your drivers. You can get a Replacement HDD here is the system is no longer in warranty:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136458
Will not leave busy....
If you are getting a 146 error, the HDD is failing. Back up your data, as you can then replace the HDD. No amount of tools or SW is going to change the fact that the drive is dying
2answers
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
2answers
I have a Dell XPS 400 with Microsoft XP. It recently shut down with a Blue screen stating that a recently installed driver is possibly bad. I was able to restart the CPU after a while and with in a few...
don't reboot instead reinstall the windows may solve this problem.i recommend ur xps laptop use windows vista ultimate because its have great performance i heard.
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
1helpful
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
