Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Take apart MX3000
I'd like to open up the remote to straighten the LCD screen. Anyone know how to open her up?
Please refrain from pressing too ******* the screen. The pressure responsive clear cover in front of the LCD screen can crack, resulting in a defective touch screen. If you truly wish to disassemble the unit, then there is a way. But please understand that this WILL void your warranty.
First, remove the battery cover on the back and unplug the battery pack, then remove the battery pack. Now, if your fingernail is strong enough, you can wedge it in between where the dark colored rear plastic plate and the light colored front plastic plate meet along the sides. Start in one spot, then slowly and gently work your way around the entire remote. If done properly, the two sections should begin to unsnap from each other. Once the back cover is unfastened, be cautious of the black wire connected to the ground shield on the inside of the back cover. Now you'll notice 3 seperate wire harnesses attached to the back plate that plug into the circuit board. Carefully unplug these harnesses. Don't worry if the small, black round device on one of the harnesses falls off the back plate. That is just the small speaker and can easily be pressed onto the back plate again. Once all the harnesses are unplugged, move the back cover around until it is out of your way, without pulling the ground shield wire loose. Now you should be able to see the green circuit board. The next step is to unfasten the wide, flat ribbon cable on the lower left side of the circuit board. Look closely where the ribbon cable is plugged into the white colored slot. On the sides of that slot are small black flanges. Carefully pull those flanges away from the slot to unlock the ribbon cable. You won't have to move the flanges very far. Now gently remove the ribbon cable from the slot and leave it there for the time being. Continuing, you'll need to remove the 4 small phillips head screws that secure the green circuit board to the front plate. You can possibly use a #1 phillips head screwdriver, but a #0 or smaller is preferred. Once all 4 screws are removed, you can begin to gently lift the circuit board away from the front plate. Be cautious while letting the ribbon cable slide through the slot in the circuit board. Once the circuit board is removed, you should be able to access the rear side of the lcd screen assembly. The screen assembly simply snaps onto the back side of the front cover plate via 4 small grey plastic snap studs. If your screen was already crooked in the remote, then one or more of these plastic snap studs may be broken. If so, then a few small drops of hot glue may help hold the screen in its correct position. Now, if the screen assembly was already in the correct spot, but the internal sections of the screen are what were misaligned, then it may be beyond self-repair.
This is as far as I can help with this. I'm sorry if I left out any steps, as I'm trying to conjure this from memory.
Good luck.
Posted on Oct 04, 2008
I had the same problem and all did was just press down on the screen and move it.  Don't worry, it wont break or anything.
Posted on Aug 28, 2008
My lcd screen has a black mark through it, nothing shows up
Posted on May 28, 2008
Dynamic entertainment system mx3000
Get rid of it, and buy a new one. It will be the best.
Oct 17, 2013 | Universal Remote Control MX-3000 LCD...
WE love our MX3000 and it was installed about 9 months ago. However, now Cox has changed all the channel numbers from the 700's to the 1,000's. I cannot reach the guy from Eagle Sentry, here in Las...
Ask Cox cable to send u a new listing of the numbers of channels has been changes or u have it already?Sorry no,not really.Read ur universal remote manual,just reprogram the channels numbers that all.
Aug 10, 2011 | Universal Remote Control MX-3000 LCD...
Mx3000 does not charge when in cradle. nothing
I agree with ceocass, however if you find that the contacts are clean and you have made certain that the charging cradle is plugged in you may simply need to replace the battery.
Please note that the replacement batteries for the MX3000 Universal Remote Control, p/n's Powercard PC046067-H & PC036067V3 have been discontinued. now carries an alternative battery, p/n PL056067V3 which is a 2,100 mAh typical capacity battery that can be used as a replacement.
Please confirm that the connector type is the same as your battery prior to placing your order. We only carry this battery with the Version 3 connector which has a built in pressure release tab.
The link for the product page is:
If you have any questions please contact at
May 27, 2010 | Universal Remote Control MX-3000 LCD...
My display is broken
Universal Remote Control, Inc.
500 Mamaroneck Ave.
Harrison, NY 10528
Technical Support
1(800) 901-0800
They do not repair the MX 3000 remote anymore but they will replace it for $400 when you send them yours. We have some replacment screens and can repair it for $300 even on pre 2005 models.
Extreme Home Cinema 303-359-9035
Dec 17, 2008 | Universal Remote Control MX-3000 LCD...
Dynamic Entertainment System MX3000 - Frozen!
I have the same problem with my MX3000 entertainment system battery by PowerCell P/NO: PC046067-H. Need a replacement battery.
Feb 07, 2008 | Universal Remote Control MX-3000 LCD...
remove the batterys and look for 1 to 4 screw holes. have a thin bladed knife to push in on the seam and to pry open. I start at the battery box side.. once apart you might have 1 or 2 small screws holding the curcit board down and some prongs to . Remove the srews and push the prongs to the side and pull off the board . you will be at the rubber button side. clean as much as possible. notice the inside of the buttons. you can use a pencil to draw on the inside to act as a conductor for the bad buttons that are worn
Dec 31, 2007 | Universal Remote Control MX-3000 LCD...
what kind of battery does this thing take?
Nov 06, 2007 | Universal Remote Control MX-3000 LCD...
MX 3000
hold down the main button for 10 seconds... Hit factory default... Re download your program
Oct 24, 2007 | Universal Remote Control MX-3000 LCD...
Broken LCD
You have to go to mobile repairer. As u dont have tools for it, u might break it.
Sep 20, 2007 | LG Shine KE970 Cellular Phone
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
1,385 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
