Question about RCA F36650 36" TV
RCA F36650 Television . . .
When I turn it on I do not get a picture, but I do get a high pitch whistling sound.
Is this a problem that can be repaired? Or is the set shot?
  • socialorphan Apr 27, 2008
    I have the exact same problem. The TV is less than 4 years old.
  • CapitoDC Dec 13, 2008
    You got it correct and I had it replaced for $150.00.
    Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
It can be repaired. It sounds like a bad high voltage transformer or something in that circuit. I would take it to a TV shop and ask for an estimate. It might be costly to repair.
Posted on Nov 21, 2008
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
Makes a high pitch "chirping" sound when I try to turn it on
if its a hi pitched whine it could be the horizontal output xfmr make sure all solder joints around the xfmr are solid and the xfmr mounts are tight it sounds as if your hearing the 15,750 hz. horiz. signal
Sep 17, 2009 | RCA F36650 36" TV
Same problem, high pitched noise over regular sound and no pictur
No guarantees with this diagnosis. But it sounds like an HT ( high tension) leak This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.Ther lamp may also have been affected by the HT leak. The safest option for you is to call a service technician to it, as opening it up could cosntitute a a danger to the unskilled.
Aug 12, 2009 | RCA HD56W58 56" TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
No picture no sound only the power light turn on and off
Hmm, sounds like a fuse has blown, and this is a problem that I recommend only those comfortable around high voltages try to fix......
Dec 22, 2007 | RCA F36650 36" TV
No picture High pitch squeal RCA F36650
Confirm service # from back of set = F36650 YX01..........
Transformer red HV lead attaches to CRT & Horiz output
xistor is on heatsink next to transformer = 2SC5148 .........
Rca part # 257805 or ASTI 2078 and 237470 xistor............
Do not use a generic transistor = name brand only............T.
Please rate this solution..............
Nov 12, 2007 | RCA F36650 36" TV
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
