either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
