Question about Wharfedale DVD-M3 DVD Player
How can I reset a whafdale dvrhd400
Tried to tune it in to my virgin media v+ box and totally lost the picture and the display on the front says root on the front if I put in a dvd disc to triy and retune in to my TV.
Any help would be ace.
Thanks
Phil
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
Touch function not working virgin mobile chaser
cuando mi pcd virgin mobile lo prendo se que da frisao en la parte de inicio
Nov 25, 2013 | Virgin Mobile PCD Chaser Prepaid Cell...
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Oct 22, 2017 | Polaroid 4241-TLXB 42 in. LCD Television
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
My virgin media box is stuck on ap:52 with a virgin media picture on the television, it will not load up.
hope this helps... unplug the box or switch power off then switch back on but hold the on/off button as its powering up until you see the word stop on front of box then it should work ok ..hope this helps
Oct 10, 2009 | Samsung DVD-V6700 DVD Player/VCR
TV suddenly lost colour - gone black and white Virgin Media.
most likely the problem is due to a "lock up" you need to reset the system, unplug the set, and look in the back panel (I am assuming it is a digital (flat screen tv?) for a small (usuall) red nipple, again making sure the power is unplugged, depress the nipple with a bll point pen for about 5 seconds, wait a few minuets, and plug the set back in, you will most likely need to go to your menu for set up again, but you will be starting with a clean slate (so to sleak) and the tuner should then correctly pass the signal though
Sep 15, 2009 | Televison & Video
No sound when plugging a Virgin Media V+ box through HDMI
have you tried a hd cable this could be the answer if not get back on to virgin as they supplied the box etc they should sort this for you
Sep 03, 2009 | Hyundai ImageQuest HLT-3270 Television
Samsung virgin box
Its a problem with the power supply, if its a legit box, phone virgin media they will swap it for you..
If its not a legit box, phone who ever you got it of, they should sort it out for you from spares they have.
Nov 29, 2008 | Samsung DVD-V6700 DVD Player/VCR
Commtel control freak 4in1 remote
have a 4 control freak uni remote lost booklet would like to down load one pls also have u code for remote media windows pc
Dec 21, 2007 | Televison & Video
Wharfedale DVD-M3 DVD Player Logo
156 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jonathon summesfield
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
