Question about Dishwashers
Sears Kenmore dishwasher 1996 model 7636
The dishwasher either will not start or shuts off while running. Sometimes slaming the door works. Sounds like a door switch problem. Where is the switch located ? what else could the problem be?
  • Tedharasti Apr 16, 2008
    Sears Kenmore Dishwasher 1996 model 7636
    You still haven't told me where the door switch is located
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 16, 2008
  • Maanita Chadha
    Maanita Chadha Apr 16, 2008
    The door has problems
    When your dishwasher door has a problem, check these:
    Latch
    Springs
    Hinges
    Door seal
    Latch
    The
    latch on many dishwashers is adjustable. If your door is easy to close
    but difficult to latch, adjust the latch to let the door close more
    easily. If you can't see any way to adjust the latch, yours may be
    fixed in a certain position. Check for other reasons for the latching
    problem.
    If the latch has worn out in a way that makes it
    impossible for you to close the door properly, you probably need to
    replace the latch.
    Springs
    Your
    dishwasher has two springs that counterbalance the weight of the door.
    If either or both of these are broken, the door feels quite heavy and
    you need to replace both springs.
    Hinges
    The
    hinges are important to the door closing properly. If they're bent or
    deformed, you probably need to replace them. Once bent, only rarely can
    they be straightened well enough.
    Door seal
    If
    your dishwasher is new--or if you have just replaced a door seal--the
    door may be difficult to latch for a week or two. If the tightness
    persists, though, try adjusting the latch, if it's adjustable. If it's
    not adjustable, there's probably nothing you can do immediately. But
    try running the dishwasher on the highest heat cycle to help the seal
    conform to the door. Otherwise, the seal should compress over time.
  • Maanita Chadha
    Door switchThe
    door switch is important because, if it's defective, the dishwasher
    won't work at all. To reach it, you need to remove the control panel
    cover, or sometimes the interior liner of the door. If it's defective,
    you need to completely replace it.
My Kenmore HE was started, the doors locked, and a few seconds later, the whole thing shut off. Tried every cycle to see if changed it but only had the same results, help!
Dump it. sears has a horrible reputation with their appliances. I owned a sears dishwasher for two years until it broke down. Fukk sears.
Apr 01, 2016 | Kenmore Washing Machines
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Dishwash
sometimes those dispensers become defective,, make sure nothin is obstructing it from opening possibly dishes or rack attachments,, if not then u will need to order a new dispenseer assembly if this is a whirlpool built kemore,,,( kenmore just puts there name on aplliances, they dont build them) just to let u know if u didnt know already...
deteremine your model number go to sears online check out there parts and service page and research parts by puttin in your model number and determine the part number for your model ,,,, i believe they vary from 20 to 60 dollars ,, this is somethin you could do just have to get part and seperate the panles by removing the screws all around the inside door.. hope this helps
Jan 31, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Dishwasher leaks during the wash and rinse cycles from the front
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Apr 04, 2009 | Kenmore Dishwashers
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Kenmore b/in dishwasher model # 665
There is an Interlock switch on the door that stops all funksions of the machine when the door is opened.
WARNING! BEFORE WORKING ON THE MACHINE DISCONECT POWER FROM THE MACHINE.
Generaly you need to remove the Control Panel Top Of Door (sometimes the whol inner linning of door) to access the Micro Switch that performs this very nessasary function,this switch should be the problem and will need replacing.
They are very cheap to buy.
Take it slowly,take photos before starting work and during so that you can not forget how it oes back together.
Dec 14, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Sep 24, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Liftmaster Opener
are eyes aligned and led on for each eye. where is trolley. wedged in up position. take out safety bolt and see if it will run. need more info to help more like model,age,etc
Jun 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door won't close
I have the same dishwasher and the latch has never worked. Finally after 9 months and many service trips I went back to the store and they gave me a new dishwasher. Dealing with Sears has been a nightmare.
Jan 22, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
203 people viewed this question
Top Dishwashers Experts
