Question about Dryers
My dryer was working fine then i opened it put my jeans in the dryer pushed the botton and it stoped working i press the botton it just makes a buzzing sound and doesnt do anything.
    New Friend:
  • 3 Answers
Try to see if dryer will run empty.If so contact me back.
Tony Fixit
Posted on Apr 17, 2008
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer LER5636PQ0 push to start keeps failing to work
You could have a worn door switch . Push in on the plastic piece which closing the door actuates and press the start botton . If it starts ,several times , then replace the door switch . Pt # 3406107 . Do this after you put the 2 thermal fuse (slim white piece with 2 wires attached )wires togather for testing purposes only . BE sure to unplug dryer before doing ANY repair testing first ! If it starts by jumping the wires , then pt # 3392519 fot thermal fuse .
Jul 14, 2009 | Whirlpool Dryers
Heating element turns on, dryer will not spin, belt is good
Check the door switch, thermal fuse(s) and check the start button. You may have burned contacts in a switch. Check the switch in the motor, with the power cable disconnected. Take the screws off, open the switch pry it open with a flat screw driver. Then pull the contacts out with one at a time with the cable connected. File, sand, use a wire brush do what ever you have to to clean the contacts. The press it back in, do the next one. One at a time, put them back press the switch make sure the contacts, make contact with each other. The top contact has to make contact with two contacts ether or when you press the switch. It should be to one side or the other making contact, this will make sense if you decide to open the switch. Put it back together and check the dryer. This is not difficult to do, it might be intimidating but not difficult.
May 23, 2009 | Dryers
How do you unlock the control from not working
Here is a link to the user manual - it will show you a picture of where the hold switch is located:
http://www.rcaopal.com/pdf/M40xx_IB.pdf
Mar 30, 2009 | RCA OPAL M4001 MP3 Player
Doesn't work at all
Check the door switch. With the door open, on the upper right side of the tub opening there should be a little lever. Push on it and you should hear a click sound. If the lever is broken or no click sound, you need to replace the switch. If that checks good check your circuit breakers and power cord and outlet.
Apr 08, 2008 | Kenmore 63032 Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Intermittent ignition
my dryer just stoped. when i press the start button it makes a noise and then theirs a small burnig smell if i turn the tumbler it works for awile then back to the dryer being stoped again.
Dec 09, 2007 | Whirlpool LGR8648 Gas Dryer
Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
  • Fuse could be bad -- Check the fuse for a break inside. If it’s bad, replace it with an identical fuse.
  • Temperature switch could be bad -- Use VOM to check the switch. Set VOM to RX1, remove leads and touch the probes to the switch's terminals. The reading should be zero or infinity. Turn the switch, and the reading should change from zero to infinity or infinity to zero. If not, the switch is bad.
  • Thermostat could be bad -- Set the VOM to RX1, take a lead off one of the two outside terminals and press the probes to the two outside terminals. There should be a reading of zero. If not, it's bad.
  • Heating coils may be bad -- Set the VOM to RX1 and remove the leads from the coil. Press the probes to the terminals. If the reading is zero, the coil is bad.
  • Timer could be bad -- Disconnect the leads from the motor. Set the VOM to RX100. Clip the probes onto the leads. If the reading is infinity, the timer motor is bad.
Oct 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dryers Logo
52 people viewed this question
Top Dryers Experts
