Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Canopus converter drops in the middle of capture
I have been using my Canopus 110 for about 3 months and have a problem. It seems to drop in the middle of capture. Sometimes it will capture for several minutes, other times it will capture for only a few seconds. I have tried it in both Adobe Premeire CS3 and Movie Maker and it does the same for both. It some how disconnects from the computer and then a few seconds later I get the pop up saying my Canopus device is reconnected. I am using Windows XP Pro with service pack 2. Can anyone help?
Install xp service pack 3.
Posted on May 19, 2008
I cannot get video from my VHS through my canopus 110 to my computer. The VCR works fine. It is attached as suggested. With my analog camcorder I have no problems.
I had this same problem. Took it back and got my money back. Was trying to use with iMovie. Was told I needed at least the ADVC300 (also known as Canopus). Not sure why, but the 300 did the trick. Could be other problems, though. Maybe your firewire is bad, or the port on the computer. Or the connectors you're using between the VCR and converter. I hope it isn't too late to exchange any of the equipment you bought. Usually it's 14 days for these things. Good luck! It is hard to pin down these problems!
Nov 02, 2011 | Canopus ADVC-110 A/D Converter...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
156 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
Alun Cox
Josh Whitehead
Josh Whitehead
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
