Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Machine is leaking
For a couple of months now the steam knob on my Gaggia has been flaky, in particular, when I turn the knob to the closed position it doesn't always close, the steam keeps flowing.
Last night I decalcified the machine. I noticed it leaking all along the right side, front and back during the decalc.
I took the brew unit and dreg drawer out so I could see inside and every time it ran decalc fluid through the steam wand, I could see fluid leaking down the right wall inside the machine, also through the back.
The machine is 2 1/2 years old and out of warranty now. We're not feeling too much like spending $100 to ship from CA to NY and waiting 3 months just to find out what the problem is and what it will cost like the last time we did a repair (that repair was under warranty but the warranty expired 6 weeks after they received it and they tried to make us pay for the repair).
Any suggestions?
  • 1 more comment
  • webwench Apr 16, 2008
    My machine is a Gaggia compact digital.
  • Anonymous Jun 01, 2008
    I'm having the same problem! My Gaggia Syncrony Compact (almost 3 years old) is leaking water down the inner-right hand side of the machine... it appears as though there is water dripping through the steam wand (even when it's closed) and what doesn't go through the wand is dripping from something (??) inside the machine.  I'm actually losing a LOT of water this way (based on what I mop up from the counter).
    I'm about to run a decalcification cycle, to see if there are deposits in a valve somewhere.... does anyone have other suggestions.
  • kmoelhoff Jan 18, 2009
    I have the same problem. The steam was working fine, and the valve would stop the flow but we noticed that steam was coming out the vents next to the knob whenever we would froth. Did a decalcification cycle and sure enough, water would leak down the right side. You really need to fix this problem because moisture will get onto the electronics.
    I disassembled the machine and the faulty valve. For me the valve body looks ok, but the internal o-ring on the valve stem is quite flat. Now if I can only find an o-ring replacement, I would be set. Looking at how this is built, it's no surprise that this would eventually become a problem.
    Does anyone know if there are rebuild kits for this unit?
I had this same problem. Water leakage down the inside right side of the machine after 2-3 years, into the drip tray and all over the counter. The problem became worse over time. The steam valve would not completely shut off. Because we rarely used steam to heat or froth, and because the cost of a new unit is so high, as is the cost for repairs, I was able to eliminate the problem by opening up the machine, locating the hard, small inner-diameter, plastic internal steam line (under the cover, top of the machine, right side, leading to the external steam nozzle), and permanently pinching it closed by bending it multiple times and clamping it between some washers and bolts. So now we don't have steam, but at least the expresso maker part still works fine and doesn't leak.
Posted on Dec 22, 2008
  • 3 Answers
The valve is available at partsguru.com in the US
Posted on Nov 02, 2008
  • Gaggia Expert
  • 109 Answers
The problem will be the steam valve is faulty.
Im in australia so i don't know where you could source one in the USA.
Its a very common fault.
Posted on May 08, 2008
After decalcifying our Gaggia coffee machine and it going through its rinse the messages says rinse finished close knob. The knob is closed but the message stays and the machine cannot be used as its...
A frequent problem with some of these is that the internal switch loosens up. It is a micro switch positioned so that the steam knob contacts the switch when you close the knob fully. You can try pressing in on the knob while you turn it closed and that will usually cause it to contact the switch and get you going again.
It will likely happen again and if it does you may want to open up the machine (if you are very handy with that sort of thing) and get the switch securely positioned so the steam knob closes it reliably.
Dec 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium that continues to Steam.
You need a new valve. Try getting the stainless steel valve assembly.
May 03, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium coffee maker leaking water internally from steam tap
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand. But its going to have to be replaced.
If it is silver you probably have O-rings that need to be replaced. I would use the black O-rings, not the red. The red ones are a little smaller and can leak.
Dec 01, 2009 | Gaggia Titanium Espresso Machine
Gaggia platinum leaking from milk island
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Jun 23, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium leaking underneath
Andy15 - Thanks - you encouraged me to do this myself.   I made a video as I did my repair.  The video making was more work than the replacement of the steam valvle.   Please check out my video if you have have to make the same repair.   Also - the technical support from WholeLatteLove was great.  http://www.youtube.com/watch?v=8UgVBoFd5aE
Nov 30, 2007 | Gaggia Titanium Espresso Machine
Gaggia titanium leaking water underneath
i had this same problem. the solution is simple if you are a little bit handy.
there is a bad valve inside. i called Whole Latte Love where i bought the machine and ordered a Steam Valve complete - Compact Frame
its part number GA-%0345.R and two O-Rings
the valve that comes with the machine is plastic and the new one is a brushed metal casing. my guess it will last for 10 years!
two screws on the back and the machine is open
near the front, by the steam wand, with a hose attached coming from the heater, is the valve, attached to the knob on the side
two more screws and the valve wrapped in a plastic housing comes out.
open the plastic housing, remove the insulated hose to the steam wand and the water/steam plastic hose that comes in. replace the valve, hook up the two hoses, but back in housing and you're done. attach back to knob on the outside, put back together and in 30 minutes, the Titanium is like new. no leaks.
it sounds daunting but is pretty easy and beats sending the machine back for repair. i can't go a morning let alone a month without coffee from my Gaggia. once repaired, the coffee is hotter too.
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
278 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
