Question about Pioneer Audio Players & Recorders
I own a pioneer PD-F100. A part inside broke which loads the cd's. I opened it up and found the part that is broken and I need to order a new one. I'm not sure exactly what the name of the part is. I believe it is called the loading arm but I'm not sure. Can someone please help?
SOURCE: U1 FAULT CODE
I had this same problem today.
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Posted on Jan 06, 2008
  • 105 Answers
SOURCE: Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Posted on Mar 16, 2008
SOURCE: WFMC3200UC Broken Plastic Piece
This is the Laundry defelector. It keeps laundry from getting stuck in the gasket area. If it is broken/extremely worn it needs replaced.
Posted on Jul 31, 2009
SOURCE: cdp cx300 parts schmatic
I'm having the same issue. Can you tell me where I can find the part you are talking about?
Posted on Dec 14, 2009
  • 5 Answers
SOURCE: I'm looking for a Service Manual for Pioneer PDR555RW CD Recorder
Here's a site that has the service manual and service guide (you need both). They have 2 copies of the service manual (the second and third links); you only need one of them.
http://elektrotanya.com/?q=showresult&megnev=&megnev2=555rw&kategoria=&kat2=all
Posted on Jan 15, 2010
Pd f-407 wont pick up disc
This type of repair is tricky at best because it is a multi disc player. Some discs will jam together locking up the loading bay, also! the timing gear will go out sync, or the the plastic gears will show signs of ware causing gears to slip, the final aspect is broken worm gear and cogwheels cracked or missing a tooth. In order to repair unit must be dismantled to attempt the repair.
Apr 22, 2012 | Pioneer PD-F407 25-Disc CD Changer
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
I have a Pioneer Elite PD-F100 100 disc cd changer I just bought off E-bay. It loads every disc ok, then it will not spin or recognize any disc. It just says ''No'' and then returns the disc and moves on...
Try cleaning the laser lens assembly. Also see if disc tries to spin and you may want to nudge it to start,if that dont work you more likely have a defective laser assy.
Apr 16, 2010 | Audio Players & Recorders
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Jul 05, 2009 | Audio Players & Recorders
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Mar 16, 2008 | Audio Players & Recorders
73 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
