Question about RCA 27R410T 27" TV
RCA 27R410T my tv turns itself off and on
My TV will just turn itself off and on as it pleases!?!?!?! any idea what the problem could be?
  • moirabean Oct 27, 2008
    I just don't touch the TV anymore... I only use the remote control and it no longer turns itself on/off... not the ideal solution... but it is the easiest fix... I would like to be able to use the TV to... so moving the controls to the outside of the TV sounds good...
My one year old 24" RCA was having the same problem and also changing channels on its own. I decided to do some experimenting. (Warning: High voltages exist inside a TV even when it is unplugged. Messing around inside a TV may be very dangerous and stupid.)
I found that there was a 5 wire ribbon cable that connected the circuit board with the front control buttons to the main circuit board. I discovered that if I turned the TV on, then disconnected that ribbon cable from the main circuit board, the TV was stable, it would not do anything on its own. Obviously, I could not control it either with the ribbon cable disconnected.
Since there did not appear to be any ic chips on the button circuit board, but mainly some resistors, I theorized that the buttons simply caused a certain voltage signal to be returned to the main board. I further theorized that perhaps the voltage being sent to the board was varying causing the return voltage to also varying making the main board thing a control signal had been sent.
The five wires are labled on the small control circuit board. One was labeled "key". (or maybe "keys") I separated and cut that wire. The TV was then stable. It could be controlled by the remote control, but the buttons on the front were now not functional.
I connected some longer wires to the "key" wires and ran them outside to a switch. The TV now works fine with the remote control and is stable and will not do anything on its own. If for some reason I do need to use the manual buttons on the front, I can simply flip the switch on and the buttons will work. However if I leave the switch on the TV will again be unstable, turning itself on and off and changing channels.
That is how I "fixed" my RCA.
Posted on Oct 25, 2008
I have a rca model # 27r410t TV that has (3) (red,yellow,white) composit input. I purchased a Netgear NTV 300 streaming media player that only has HDMI output, What time cable do I need to make this w
Your TV has only A/V inputs. Red and White is to connect the audio outs of the streaming media, and Yellow for video. But here, your streaming media player have only HDMI output. That is, it is compactable only to TVs, which have digital inputs, where your TV has not. A converter [HDMI to A/V] in between the two devices will do it to work. There is no other chance.
Jan 24, 2013 | Televison & Video
Rca 27r410t hdmi
This TV cannot be connected directly to streaming media.
Jan 24, 2013 | RCA 27R410T 27" TV
I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
Aug 26, 2010 | RCA 27R410T 27" TV
27R410T 27" TV: our RCA Model 27R410T has maybe 20 hrs of total us...
Ok, well the good news is prize or NOT it is still covered by a warranty, that's the law, you need to contact your local RCA office, and ask them for a referral to an Authorised service center, and you will be able to make a claim, and in any event, that's where you are going to have to take it to be repaired in any event. The Consumer Act, indicates that anything sold must be of "Merchantable" quality, clearly any unit that fails after less than 24 hours use, falls into that definition. You simply have to find a Dealer, Service center, whatever, and in all fairness, they should take care of it, there may be some costs involved, but usually not. Below is a technical Service manual, this is what I use to train the engineers to repair these units, have a look, www.electro-tech-online.com/.../36401d1261034747-rca-32-television-32v434t-need-help-repairing-atc010_training_manual-1-.pdf
May 06, 2010 | RCA 27R410T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
Front panel locked and I have no unlocking code
pls. serch webside to "RCA 27R410T" see the users menual and check how to unlock your tv.
Oct 06, 2009 | RCA 27R410T 27" TV
I Forgot my parental control code!!
to reset it just unplug it. the memory only works when there is power to it.
Jun 26, 2009 | RCA 27R410T 27" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
RCA 27R410T
hi Sounds like a dry solder joint on or near the flyback try here: http://www.eserviceinfo.com/ good luck windman
Mar 04, 2006 | RCA 27R410T 27" TV
RCA 27R410T 27" TV Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
