Question about Sony PlayStation Portable (PSP) Console
PSP memory stick stuck
I put scotch tape in my memory stick.. when i put it in the psp slot it is stucked what will i do?
  • kakashi654 Apr 17, 2008
    it seems when i tried what you said the ms seems to have crack
  • 85 Answers
Try to carefully take it out with pliers.
Posted on Apr 17, 2008
My old memory stick says "cannot read memory stick, go to settings...etc...", so i took it to a technician and he advised me to buy a new one...so i bought a new 8gig memory stick but then the...
Make sure the contacts in the PSP's mem stick slot are clean... no dust/dirt in there. Format the memory stick on your PC then put it in the PSP. If the PC can read it and the PSP can't, you'll need to send in your PSP for repairs.
Jun 30, 2011 | Sony PlayStation Portable (PSP) Console
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
Psp memory problems
have you tried using your memory stick to other units or computer?
1. if its not working it might be damage.
2. but if its working your memory slot in your psp has the problem then look for a technician that could fix your psp slot for memory stick.
i can see that your memory stick and the psp memory slot is not connecting with each other.. hope it help. for more concerns send as a message
May 21, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP 2000 MEMORY STICK SLOT PROBLME
Turn the psp on go to system settings then format memory stick then insert the memory stick and format it and it should be fine.
Jan 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory stick won't go in
The only way that I know of is to dismantle the PSP or send it in for repair. Taking the PSP apart is a very long process and although it is reasonably easy, the screws can easily be lost and it is easy to forget where everything goes when putting it back together. I would reccomend putting a small screwdriver in the card slot to find out if there is something stuck in it but you cannot tell what you are doing and the contacts for the memory stick are quite fragile and you could easily damage them.
If you are prepared to take the PSP apart then post a comment and I can guide you throught the process.
Hope this helps
Mowcius
May 16, 2008 | Sony PlayStation Portable (PSP) Console
My psp fell and the memory stick duo popped out
they will most likely open the psp and try to repair the problem.
Mar 30, 2008 | Sony PlayStation Portable (PSP) Console
Button stuck or somethong
Round directional button? well if it is a button not an analog stick just take off the psp plate the face if you will and put it back on it wont be stuck if its the analog stick buy a new base not those tops a base were youll have to open up the psp and replace it ------------------------------------------------------------------------
( III -------------------------------------------- )
I == + == I PSP Expert I /\ I
I III I I [ ] OI
I I I X I
I ---------------------------------------------- {home} - Vol + PSP ( ) .?\ select start
Jan 24, 2008 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
