Question about Sharp 27R-S50 27" TV
Sharp tv/model no.27R-S50 . need service setup info.
I need to adjust the vertical hight/alignment. does anyone know the service setup proceedure?
Press and hold volume up, channel up, then plug in tv. Should go into demo programming mode, worked on mine.
Posted on Jan 08, 2010
My sharp has blac and white pic how do I fix
Check whether the color system setting is set to right selection.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 26, 2015 | Sharp 27R-S50 27" TV
I have a Sharp 27-r-S50 that the remote is lost, bought a philips universal remote and need the code
Hi, We'll hope you sucessfully competed setup first, as there are actually multiple " supplyers " of manufacturing for each brand the correct codes are a little specific to " maker" an " F.C.C. I.D. number "will tell you a makers name. there are brand name remotes that offer profiles also, and there can be as many as 4. A good examlpe would be if the remote has a screen on it. So for example again sony owns akai and some admiral tv's are made by sharp-so double check maker's name through the fcc id #( would brobably be located on same taq as serial number etc..) then use that manufacturers set up code. I hope this helps, and good luck. Prodzilla
Apr 07, 2011 | Sharp 27R-S50 27" TV
We need the code for our sharp t.v. We do not have the manual.
with the TV set off.
press and hold vol down on the tv set and push clear on the remote set for 5 seconds, if that dosent work you need a new eprom IC instaled in the tv set.
regards,
daniel.
Jan 09, 2009 | Sharp 27R-S50 27" TV
Watching DVD or VHS ...
I could not find the manual for your TV, but I did find one for model number 27N-S50 so hopefully they're very similar. If you DVD/VCR is connected to your TV with composite cables (the RED, WHITE, YELLOW cable set) then you need to change the input mode. There should be a button labeled Input on your remote and pressing it will cycle between the various inputs (Cable, Input1, Input2). I would guess your DVD/VCR is connected to Input 1. If you have lost the remote you should be able to get to the other inputs by using the channel selector button. Tune the TV to either the highest or lowest channel in memory and then press either the CH UP or CH DOWN button on the TV to cycle through the various inputs.
The other thing you should know is that there is a recall on this TV related to the power button. I discovered this while looking for the manual on the Sharp website. Go to this website:
http://www.sharpusa.com/products/support/0,2309,,00.html
Type 27R-S50 in the model box and select Television/Home Theater Projectors in the Product box then click on Get Results and you'll get information on the recall.
Also, if the info I've given about how to select the input does not work, there are links on the above site to help you get the correct manual.
Lastly, I don't get paid for this. I know it's a strange hobby, but I like to help out when I can. I hope you'll take a moment and give a prositive rating if this information has been helpful to you. Nearly half of the solutions I've posted have never been rated. Thanks and good luck.
Jan 03, 2008 | Sharp 27R-S50 27" TV
I FORGOT DA CODE FOR MY TV
i don't remeber ,the tv program code. at the sharp tv.
Nov 27, 2007 | Sharp 27R-S50 27" TV
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
Sharp 27R-S50 27" TV Logo
334 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
