Question about Canon CLC 4000 Copier
CLC5000 fuser oil into clc4000
One of my employees filled a CLC4000 with CLC5000 fuser oil, when he turns on it, it turns off by it self, is that possible that the copier had been damaged?
Hi re f  error   oil is same the error is caused by overheating rollers or thermistor rpoblems i have had this  when fixed  (or try *28*  at same time then function- then fuser then error  release should clear it- Mike
Posted on Nov 28, 2008
How do you put fuser oil into the CLC4000 where is it located.
Posted on Aug 14, 2008
    President:
  • 2,072 Answers
Chance are almost zero. I dont believe there is any differenece.
Posted on Apr 26, 2008
I would like to know how i file a complaint of poor customer service by one of your employees?
first --this fixya site and not a place where there is face to face employees
second --- ring the manager of the operation direct your self and make a statement
last---get the company web page up and go to contact tab and fill out the form
Jan 19, 2017 | Computers & Internet
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
May 11, 2010 | Canon CLC 4000 Copier
in the back of the copier there is a circut breaker switch put it into (!)
Mar 19, 2010 | Canon CLC 4000 Copier
How do I top up the fuser oil on a Ricoh CL7000 printer does not seem to be anything in the maintenance manual
You don't. The Type 7000G Maintenence Kit is the self contained oiler unit, rated for approximately 30,000 prints on 8 1/2" x 11" stock. If a person were to try to "top off" the oil, where would said person locate the correct type of fuser oil. Not all fuser oil is the same, viscousity wise as well as chemical composition. What an expensive mess.
Sep 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Canon CLC5000 fixing cleaning rollers
only the lower one YOU MUST HAVETHE UPPER ONE IN THE MACHINE THERE IS A SENSOR THAT TELL THE MACHINE
Dec 02, 2008 | Canon CLC 5000 Copier
ERROR CODE E020-02D0 on Canon CLC4000
you need a full developer change . do you know how to do that
May 15, 2008 | Canon CLC 4000 Copier
CLC 4000 FUSER ERROR?
The problem is that the lower fusing roller has shorted out and it may have shorted out the DC- Controler. Did you resently replace the lower fixing lamp. If yes it is wise to replace the dc- controler at the same time. A suggestion from a Canon tech pub... Good Luck....
Apr 15, 2008 | Canon CLC 4000 Copier
Resetting the fuser oil message
Well, all you need to do is fill the tank on the back right of the machine. The oil pump has to pump it up to the sensor in the fuser. It will eventually go out, or you will get an SC570 code.
Mar 04, 2008 | Office Equipment & Supplies
Davor skopje
sorry for my bad english but, this is an answer:
your problem refered to a cleaning web, of the upper fuser roller, check this web and you can see, its finish, if you havent this, you can turn arround, but observe vary well his position, then
after of remplacement, you have reset de web alarm,
when you relocate all that pieces in her order, turn on the copier, then after this send the error code, push the buttons in this secuence...
( * ) ( 2 and 8) thogether ( * ) to enter service mode
then push ( func )
after push ( fuser )
after push ( E005-RLS )
and then turn off and turn on the copier and ready, thats all
if not work, check your sensor web position and repeat the E005-rls procedure
for more info, you can obtain the clc5000 service manual to download in www.yoreparo.com forum,
or send me an email, can i help you, good luck, budy.
Dec 20, 2007 | Canon CLC 1000 Color Copier
135 people viewed this question
old marine
old marine
