Question about Panasonic KX-TG5771 Cordless Phone
Base not responding
The phone works, but not the base. I can't get one of the phones to recognize the base or register. None of the buttons will work on the base. I've tried to turn it on and only the message button will light up. Anyone have a solution before I ditch it.
caty
  • Anonymous Sep 17, 2008
    Same problem, base display shows letter "A" (not in manual) and not one of the buttons on the base work. The phones still work though.
  • Anonymous Jan 16, 2009
I have the same thing....
Posted on Jun 23, 2008
My EnGenius cordless is not responding.You can not answer or make calls on it.I tried to turn it off-it's not responding
It has somehow unregistered with the base unit. Go to the base with your handheld. On the handheld menu, you can select "register". Try that by first. Next, press the gray (usually) button on the base unit and register the cordless again. If no go, de-register the cordless and try the steps again. Post for more if those did not work.
Feb 17, 2015 | EnGenius Lands Phones
My handset is showing register
Your handset needs to be "registered" to work with your base station. This is so that the handset will respond to calls on your phone line and not your neighbor's.
Your manual will detail the procedure to register your phone with the base. If you require further assistance, please specify the make and model of your phone.
Jun 06, 2012 | Lands Phones
What do you do when your phone says not registered and none of the buttons work after you change the battery
Try unplugging the base unit for a minute, then plug it back in and give it another try.
Jun 30, 2010 | Vtech 9009111 Cordless Phone
Base unit not recognizing any handset
I recommend that you unplug the other unit and then register each phone separetly. While trying to register one phone make sure the other is un plugged.
May 29, 2009 | Panasonic KX-TG2740 Cordless Phone
I have a TWX955 cordless phone. one of the recievers is a waterproof phone. Instructions said the rechargeable battery was already in the phone. (all of the other phones required me to install the battery...
Take the cradle for the waterproof phone and plug it into the outlet close to the answering machine base. Hold the waterproof phone in one hand, with the other press the "menu" button, press up to the "register phone", then press "menu" again. The answering machine base should say "registering phone". Once it does press the "#" key on the waterproof phone and it should say registering phone. When they beep the waterproof phone should be working. The reset instructions in the owners manual may work if you move the WP phone and cradle close to the base. I stumbled onto this method after reading about a newer model. As i took the WP phone downstairs the # key would activate the registering feature but would when I walked back upstairs. So i figured Id take both downstairs and BAMMM, it worked. Good Luck all! BTW mine came with a battery, and uniden probably hasnt figured this out either.
Dec 26, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Cordless phone not working
read the user manual and see how to register the phones with the base unit
Jun 17, 2017 | Panasonic KX-TG5673B Phone
Panasonic KX-TG5771 Cordless Phone Logo
232 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
